Civic 91 spark plug wires keep popping up!!?? - Honda-Tech
Old 01-13-2009, 06:33 PM   #1
New User
Default Civic 91 spark plug wires keep popping up!!??
Hi guys,
I've got a question in regards to a problem I have been having with my spark plug wires.
For the last several weeks my plug wire on the number 3 piston keeps popping off the plug or "almost" off the plug because it does not stop the engine, just makes it run really rough. I have tried cleaning the cable and switching them around (at the cap aswell, of course) which worked ok untill I started driving hard and then I have the problem again.
So I was wondering if anyone knew what is happening and how I could fix it?
Thanks
jjjr is offline   Reply With Quote
Old 01-13-2009, 07:14 PM   #2
D16SiHatch's Avatar
Default Re: Civic 91 spark plug wires keep popping up!!??
are they the right plug wires? i know when i tried installing a6 plug wires on my y8 head they didn't want to stay on and i had to trim them to fit properly.
are the spark plug seals in good condition? if you're getting a lot of compression leakage it will lead to high crankcase pressure, and that pressure is going to find the easiest way out. is your valve cover vent thats supposed to be plumbed into the intake connected properly, or by chance is it plugged off?
D16SiHatch is offline   Reply With Quote
Old 01-13-2009, 07:51 PM   #3
Italix's Avatar
sounds like you need to tighten the plug in that cyl. It might be loose and be leaking pressure and popping your plug wire off.
Italix is offline   Reply With Quote
Old 01-13-2009, 09:07 PM   #4
Rainman
SIred91's Avatar
Quote:
DING DING DING ^^
Don't just go "switching them around" LOL........holy ****.
SIred91 is offline   Reply With Quote
Old 01-13-2009, 10:12 PM   #5
slow88si's Avatar
That's what I would check.
slow88si is offline   Reply With Quote
Old 02-26-2009, 02:21 PM   #6
New User
That was it, Thanks. All of the plugs where loose, didn't know that they came loose....
All fixed now :-)
Odd Spark Plug Wire Issue Svell Honda CRX / EF Civic (1988 - 1991) 3 03-31-2011 01:57 PM
HELP! Sparkplug wire pops out! Oil on spark plug! JDM Approved Honda Civic / Del Sol (1992 - 2000) 10 08-20-2005 03:55 PM
spark plug wires popping out? bey Honda Civic / Del Sol (1992 - 2000) 9 10-31-2003 07:13 PM
MSD Wires solowerks Honda Prelude 1 08-06-2003 09:50 PM
Spark plug wire keeps popping out. Need help! AllmotorJunkie Acura Integra 5 07-27-2003 03:45 PM
Tags
cable, civic, crx, loose, off, plug, plugs, pop, popping, pops, problems, spark, sparkplug, wire, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
