Checking Main Relay, with pics!!!
#26
Re: Checking Main Relay, with pics!!!
I have a 1994 Honda civic lx 1.5l non vtec I pulled off my main relay [ mitsuba rz-0132 ] and it is numbered differently than above. I don't have a number 4 pin, it goes..
7 8
5 6
3 (clip attachment)
1 2
7 8
5 6
3 (clip attachment)
1 2
#29
Ok so aside from all the "not getting certain signals from ecu etc." one of my wires actually came disconnected from the socket that connects to the "little box" aka the main fuel relay. I believe its the #7 the fuel pump. How do i manage to fix it/get the wire back in the socket??? Someone please help
#30
how did it come out? did you just pull on the wire too hard it stripped out of the crimp terminal and all you see is a bare wire?
if you need to depin the terminal, use an eyeglass screwdriver and stick it in the front and slide out the pin.
#31
you can try to be a bit more descriptive. you know like a picture.
#32
take the pin out.
to fix it right, you really should get a new crimp and crimper. which is not realistic.
to fix it so you dont have to worry about it, pry the old one apart and do your best to crimp it again.
another method is to go to the junkyard, cut off a 3" section of wire with the same pin, then solder the new end to the old end.
but this is not a huge problem. if you are having a hard time understanding what im saying, find someone who knows some basic electrical knowledge and ask them to fix it for you. its pretty obvious what to do and there are a number of ways to make things better.
#33
Old Fart
one thing that confuses so many people, is that the ECU will only send power to the main relay for a couple of seconds to prime it, then while the car is being cranked, it detects that the engine is turning through the dizzy, and turns off the pump when it doesn't detect those pulses. This is a safety feature. Even carbed early Hondas without an ECU have a safety relay that does this same thing
PGM-FI Mai Relay fix PGM-FI Main Relay problems and fixes. 94
The firs test that should be done is to unplug the relay and test for the 3 powers
1- 12V constant, hot at all times
2- 12V switched power, hot in run and start.
3- 12V switched power hot when cranking to start only.
If you have all 3 powers check the black lead for continuity to ground.
You do not need to know the wire colors or pin positions to do this test. 94
#34
please one information , first thank you for your video, great. i have one crx 93. i have problem perhaps in this main relay, my is rz-0159 similar at rz 0132, if i did this that you shown and my car turn on, i can walk with this clamps 30 km = 18,6411 miles?? isn"t problem ?
with this test , the problem is this main relay?? have to change?
ty
ty
#35
Hi Ahknood , thanks for the diagram, sequence to inspection the main relay, great. how i can if this main relay is the rz-0159 , or the similiar rz-0132 ? my car is crx 93 and have this main relay, without conector number 4. your dont have number 6, what the sequence? Do you have? thank you! obrigado!
#36
Thanks you, found your post very informative but unfortunately it is not my problem. Don't know if you have had the opportunity to read my post but it is definitely a mind bender of a problem
