carbureted sohc zc mechanical timing question
Hey guys
I just put in a sohc zc with carbs. I took the carbs off and just swapped in my d16a6 manifold and all other parts.
Now though, I don't know how to set the mechanical timing.
Is it the regular dx hf setup parallel to the cylinder head or the si method where I align the cam mark with the rear timing belt cover
oh and it is in a 91 crx si stock pm6 ecu
I have the crank pulley setup right I just need the camshaft .
Thanks
edit, If anyone knows the ignition timing that would be nice to know because the d16a6 is 18 btdc
not sure what the carb sohc zc specs are
I know everyone says it's the same as the d16a6 but I don't know if thats the mpfi or carb version, or if they are the same
Thanks for any input
heres my dilema
I had a carb sohc zc before and used to put it in the dx/hf orientation. But the 18 btdc on he ignition timing had my distributor all the way to one side.
So either I was wrong on the mechanical timing or the ignition timing is suppose to be 16 btdc
Thanks
heres my dilema
Re: carbureted sohc zc mechanical timing question
At TDC If I take the valve cover off. Is there some way I can tell where the cam should be by the position of the lobes?
Good, Bad…I'm the one with the gun
Location: Trapped in time, Surrounded by evil, Low on gas
1 Post
it all should be exactly the same, the camgear fits only one way to the cam and the marks should only line up one way as well. drop a long zip tie into the first cylinder through the plug hole and rotate the engine until you see it top up.
I found the tdc on the crank.
The cam gear is already on. The one messing me up is what do I line up the cam gear with when I tighten down the belt? The difference between the dx/hf and si is only 1-2 teeth
ZC = SI / D16a6 equivalent.
Go with the 1.6 timing because thats what you have.
if you dont feel that the timing is dead on, use a timing gun to confirm.
yes thank you, I'm feeling kind of dumb now. I contacted the engine seller.
it is si timing
like picture number 2 above
ignition timing is also 18 btdc +- 2 degrees
thanks for all the help, better safe than sorry I suppose
it is si timing
CivicRaping
03-17-2005 04:21 PM
sporty240
04-25-2004 12:57 AM
