Car won't start. Please help.
Old 09-01-2002, 06:02 PM
AudioXtremes's Avatar
Default Car won't start. Please help.
The other day my car was sputtering and then it died and wouldn't crank. It had fuel but no spark. So I buy a msd modded cap and use some ford coil that just looks the same as a aftermarket coil. The new coil doesn't "test" the same as the old one in volts. I tested the wires coming from the dizzy that i took off the old coil. They are 12v when you try to crank it. I replaced the rotor too. Any help would be great.
By the way its a 88 hf with a b18a1 and obd-1 conv.
Old 09-01-2002, 07:50 PM
Redline130's Avatar
Default Re: Car won't start. Please help. (AudioXtremes)
Maybe your ignitor went out. I'd check that also.
Old 09-02-2002, 08:57 PM
Default Re: Car won't start. Please help. (cyber13)
what and where is that?
Old 09-02-2002, 11:09 PM
ThatRicerDaniel's Avatar
have some one crank the car look at the pulley on the side of the motor .. see if its turning. if its not you snapped the timing belt ~maybe the spark plugs coulb be fouled if it was sputtering.good luck
Old 09-02-2002, 11:13 PM
big pete's Avatar
Default Re: Car won't start. Please help. (NitrousDreamz)
could be the ignitor....my ignitor went poopoo before and the car didnt start....the ignitor is the brown thing under the coil in the distributor
Old 09-03-2002, 01:35 PM
Default Re: Car won't start. Please help. (big pete)
ok someone told me that i can't change the ignitor cause its in the dizzy. is this true? do i need a new dizzy?
Old 09-04-2002, 07:18 AM
ok well, its in the dizzy but I just replaced it and still nothing. So heres what has been replaced.
coil, rotor, cap, ignitor. plugs are good and the wires. someone saisd their is like a solenoid in the dizzy that will go out and not give my coil any amps to spark but I will still se the 12V to the coil. Is this true. THEN do I need a new dizzy?
Old 09-04-2002, 08:53 AM
zcivic91's Avatar
u could try a new dizzy..there know for going out on zc's..
however open ur oil cap and have some crank the motor...look to see if the cams are spinning..if not or they are just jumping then u broke the timing belt..
Old 09-05-2002, 07:57 AM
Default Re: Car won't start. Please help. (zcivic91)
I have a b18a1 not a zc. Also i can see my timing belt turning. Trying a dizzy today.
C-West Civic
06-06-2017 05:40 PM
jspeedy
03-31-2010 01:25 AM
jspeedy
03-29-2010 06:34 PM
carlos8
07-27-2009 08:48 AM
primal cb7
05-29-2005 09:38 AM
Quick Reply: Car won't start. Please help.
