car will crank but wont start after replacing timing belt - Honda-Tech
Old 09-20-2012, 11:13 AM   #1
Default car will crank but wont start after replacing timing belt
Its an 89 Honda Civic Dx.
Was driving home and the timing belt broke, I was in 2nd or 3rd gear when it happened.
It was a friend who replaced the timing belt and water pump, we've also replaced the spark plugs, fuel pump and filter. The car still won't start, and i'm going to talk to a mechanic today. any ideas? could the valves be bent?
thekeysarebroke is offline   Reply With Quote
Old 09-20-2012, 12:23 PM   #2
droopy128's Avatar
Default Re: car will crank but wont start after replacing timing belt
Timing probably off during reinstall.. check timing again (TDC) is it align correctly.
droopy128 is offline   Reply With Quote
Old 09-20-2012, 02:00 PM   #3
nicknack25's Avatar
What droopy said. Pretty sure timing is off. did you change fuel pump plugs and filter after you found out it wasn't starting? or all at the same time?
nicknack25 is offline   Reply With Quote
Old 09-20-2012, 02:11 PM   #4
10psiLsEf2's Avatar
recheck timing
when you installed and timed the belt. after it was all tight did you rotate the crank 2 times through all the strokes? and then realign iit at tdc and check the marks?
i dont believe this engine is a contact engine but i could be wrong. it could also be bent valves.. but you can tell by sound.
does it turn over slow or super fast?
do a compression test. but first re check timing.
10psiLsEf2 is offline   Reply With Quote
Old 09-20-2012, 03:06 PM   #5
your timming is off
jchope is offline   Reply With Quote
Old 09-20-2012, 03:08 PM   #6
Quote:
Originally Posted by 10psiLsEf2 View Post
it could also be bent valves...do a compression test. but first re check timing.
This^
Former User is offline   Reply With Quote
Old 09-20-2012, 04:59 PM   #7
Put crank at TDC. There are marks on cam sprockets that need to be in correct position. Get a manual or look on-line. You may have to do more than one revolution of crank as cam rotates one-half as fast as crank. It will be obvious.
You may be 180 degrees off on camshaft (or 360 off crank -same diff). When a plug sparks, the valves should both be closed for that cylinder. If you're off on cam timing, the valves will be in wrong position when cylinder is sparked and motor cannot possibly run.
And YES - IT IS AN "INTERFERENCE" MOTOR. There will be damaged valves unless you are very lucky.
By all means, at least get a Chilton's manual down at Autozone.
trojwl is offline   Reply With Quote
Old 09-20-2012, 05:02 PM   #8
10psiLsEf2's Avatar
Sorry for the wrong info bud!
before jumping to conclusions just set timing once more... if tht dont do it. do a comp test
let us know the results
Old 09-26-2012, 05:09 AM   #9
turns out it was a bent valve, the timing was fine. I decided to go ahead and get it fixed
Old 09-26-2012, 07:23 AM   #10
Triple check the marks on the cam and crank at TDC when reassembling..
That's pretty much the only way you can bend a valve.
Good luck.
Old 09-30-2012, 06:27 AM   #11
Well i got it back from the shop yesterday and everything seemed to be going good. but then after about 30 minutes of driving the check engine light turns on. when i pulled over i noticed there was white steam coming up from the engine, the car wasn't over heating before i pulled over.
I didn't see any coolant leaking
Old 09-30-2012, 06:57 AM   #12
Can you pinpoint where on the engine the steam is coming from? The coolant will flash as soon as it hits atmosphere. And if it's on an upper point on the engine, the coolant has merely leaked down below the leakpoint and thus you won't see any liquid leaking.
I would top off coolant, start car, watch closely and see where problem first developes.
Also check oil level and check for water in oil (will look milky). If coolant is somehow leaking at head gasket and into coolant chamber, then you will have a real probelm to address (probably head gasket). I've seen this happen before.
Good luck and keep posting progress.
Warren
Old 09-30-2012, 07:19 AM   #13
I really hope it's not the head gasket, but the repair shop did replace the head.
it doesn't look like it's holding oil at all, but i don't see a leak
Old 09-30-2012, 08:34 AM   #14
10psiLsEf2's Avatar
i would say the steam is actually burning oil,grease.etc From the shop. check what dtc came on
Old 09-30-2012, 10:29 AM   #15
The smell of the steam will be a tell-all (coolant vs. oil - very distinctive odors).
Old 10-01-2012, 06:35 AM   #16
If you had a shop replace the head then take it back to them to have the job redone if you have a problem,but make sure that you don't just have oil and grease burning off from them doing the job.
Jockone is offline   Reply With Quote
Car won't start mariposa921 Honda Element & CR-V 2 09-18-2012 05:31 PM
H22A4 Shredded timing belt BAYsikDC4 Honda Prelude 14 04-21-2010 10:48 AM
car wont start heeltoehonda Acura Integra 20 12-05-2009 12:39 PM
align cam with crank chrisknight Honda Civic / Del Sol (1992 - 2000) 1 12-09-2005 03:03 AM
Car won't start - timing belt and water pump? eurodeseo Acura Integra Type-R 35 12-02-2005 11:50 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
