car starts then dies!
when i turn the ignition key the starter turns over and starts and as soon as i let go of the key the car dies. if i hold the key in the start position it will keep running. i replaced the main relay and it did not work (waste of $60). the guy up at honda said that it might be the ignition switch. let me know asap b/c im stuck w/o a car.
thanks alot.
-Seth-
thanks alot.
-Seth-
Re: car starts then dies! (96-EJ6 B18C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivic25 »</TD></TR><TR><TD CLASS="quote"> it might be the ignition switch.</TD></TR></TABLE>
second that.
second that.
Re: car starts then dies! (boostedcivic25)
You need to make sure your distibutor is getting power while the switch is in the on position. I think it is a Black w/ yellow wire. Use an online Helms or buy one to do a check on it. If it isn't getting 12volts you probably need a switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivic25 »</TD></TR><TR><TD CLASS="quote">thanks guys got it fixed. it ended up being the ignition switch wire harness that needed to be replaced.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivic25 »</TD></TR><TR><TD CLASS="quote">might be the ignition switch. </TD></TR></TABLE>
I don't think its the ignition wires trying switching cars it should work then. j/k good to hear H-t comes through for once
