car sounds like it has a flat/dragging but tires are fine - Honda-Tech
Old 10-17-2004, 11:50 AM   #1
Gant's Avatar
Default car sounds like it has a flat/dragging but tires are fine
i tried searching but serach it out right now says "please try again later"
when driving home i got off the freeway i had my windows open and noticed the car sounded like it had a flat so i get home and i look at all the tires and nothing is flat what could this noise be?
Gant is offline   Reply With Quote
Old 10-17-2004, 11:54 AM   #2
S9i1R's Avatar
Default Re: car sounds like it has a flat/dragging but tires are fine (Ba4)
body parts or something might be dragging, check your wheel well covers
S9i1R is offline   Reply With Quote
Old 10-17-2004, 11:57 AM   #3
FairlightRacing's Avatar
Wheel bearings. They are probally going bad. Make sure the 32mm axle bolt is tight as well (the gold one you see when the little lug-nut cover is off. assuming you have 90+ Si wheels).
Could also be an impact break. Inspect your tires for a "bubble." That is an impact break and can cause the noise along with making the car pull to one side depending on bad it is.
FairlightRacing is offline   Reply With Quote
Old 10-17-2004, 12:02 PM   #4
Gant's Avatar
sigh i was hoping its not wheel bearings :/ i changed my lug stud at work and just pounded it out/used a impact gun on it that prolly fucked the wheel bearing up
i dont know i hope its the tires cuase it just happen all of a sudden as soon as i got off the freeway about a mile or two away from my house i could here it, wheel bearings are a bitch :/ good thing i work at a delaership we should have a press to press it out and such but iono if we have all the tools cuase its a Gm dealership
Old 10-17-2004, 12:27 PM   #5
Gant's Avatar
alright just drove it when i was next to a barrier u could here this silght kidna sounds like a nail in the tire but real loud, no flat sound yet, then decided to drive it around more and then all of a sudden bam the LOUD dragging sound comes on, so i drive real slow its still real loud , i come to a turn i pull a uturn to go to my house and the noise dissapers :/ is this the sign of a wheel bearing? or something else?, jeez i wish search was back !~!!!!!
Old 10-17-2004, 12:30 PM   #6
Default Re: car sounds like it has a flat/dragging but tires are fine (FairlightRacing)
ya, what he said!
ef8 h0! is offline   Reply With Quote
Old 10-17-2004, 12:31 PM   #7
Gant's Avatar
uh ok
Old 10-17-2004, 12:33 PM   #8
Gant's Avatar
Default Re: (Ba4)
Quote:
sigh i wish search was working wtf is up with the damn search ugh
Old 10-17-2004, 12:55 PM   #9
Gant's Avatar
is there anyway to check the wheel bearing/test it?
Old 10-17-2004, 01:05 PM   #10
Sobe_Death's Avatar
jack up the car, when the wheels no longer touch make sure the parking brake is off and wiggle the wheels back/forth then up/down. if it has play in any wheel, then your bearing is dying.
Sobe_Death is offline   Reply With Quote
Old 10-17-2004, 01:06 PM   #11
Gant's Avatar
Default Re: car sounds like it has a flat/dragging but tires are fine (Sobe_Death)
stupid question but i dont remember do the rear wheels have wheel bearings?
Old 10-17-2004, 01:19 PM   #12
Sobe_Death's Avatar
yes they all do
Old 10-17-2004, 01:31 PM   #13
Gant's Avatar
what would be the cause of the flat tire/dragging noise to go away? its wierd cuase when i drove it earlier it just started making the loud noise again then when i pulled a uturn to go back to my house it went away :/
1995 Honda Accord 5 Speed Trans sherrygomezrn Honda Accord (1990 - 2002) 0 05-24-2016 06:48 PM
Car losing pressure.tapping and loud cranking sound Powered by VTEC Honda Civic / Del Sol (1992 - 2000) 4 01-23-2008 08:15 PM
Feels like i have a flat tire but i dont what could it be??? envious1320 Acura Integra 23 03-29-2004 06:38 PM
Flat tire feeling in my eg Nocturnal Honda Civic / Del Sol (1992 - 2000) 5 06-16-2003 11:58 AM
Flat tire TOOLS?!?! stoopid215 Honda Prelude 5 03-22-2003 05:50 PM
Tags
02, accord, bottom, car, dont, dragging, fine, flat, honda, noise, pilot, sound, sounds, tire, tires, wrong
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
