Car jerking at low RPM why???
Old 02-19-2012, 09:56 PM
mynameizstitch's Avatar
Default Car jerking at low RPM why???
Ok i got a 1991 civic sedan ex and have an issue with my car. It will sometimes jerk at lower rpm. when im anywhere from 1,000-1,800 rpm and it sometimes drives me nuts. kinda like driving slow in second gear in parking lots or keeping the car in 2nd or 3rd gear while turning at low rpm the car will be jerking once i push on the gas to accelerate. After 2,000 rpm the car seems to run normal again. The car still runs strong and just passed smog yesterday. Completely stock motor.
***no check engine light on at all.
Old 02-19-2012, 11:06 PM
mizle's Avatar
Default Re: Car jerking at low RPM why???
is your check engine light on? flash the ecu so you can get your code or codes out. Mine did this when the MAP sensor wasnt plugged in and had a vacuum leak. Check those, mine did it from 1500 to about 1700 rpm.
Old 02-19-2012, 11:47 PM
Glowicki's Avatar
Where is the MAP sensor located?
Old 02-20-2012, 05:48 PM
mizle's Avatar
on fire wall near middle. Its with the purge solenoid it
Its the on the top right and has a 3 pin connector. the vacuum line goes to the rear of the intake manifold
[IMG][/IMG]
Old 02-21-2012, 12:41 PM
no check engine light at all.
go-fast
06-01-2007 07:14 PM
trooper0641
24
01-13-2006 02:34 PM
vietboycuhz
10-21-2005 09:27 AM
Takashi1978
15
08-20-2005 08:13 PM
Quick Reply: Car jerking at low RPM why???
