Car bogs when you hit the gas, and when driving if I floor it bogs like I am down shifting..? - Honda-Tech
Old 08-30-2006, 12:06 PM   #1
4gencivicef9's Avatar
Default Car bogs when you hit the gas, and when driving if I floor it bogs like I am down shifting..?
anyone had this I just did a b16a swap into a 89 dx 1.5 I was thinking maybe it might be a lean condition and I am going to swap out the fuel pump also I am going to change ecu cause I have a pr3 ecu that is automatic?
Just figured I post up and see if anyone has had this prob..?
4gencivicef9 is offline   Reply With Quote
Old 08-30-2006, 12:49 PM   #2
Maldito X's Avatar
Default Re: Car bogs when you hit the gas, and when driving if I floor it bogs like I am down shifting..? (4
I have the same problem, but its on my d16a6, and I'm pretty sure its my ignitor in my distributor. Other problems could be a filter and or dirty injectors. Though I'm almost certain its ignitor that's bad.
Autozone can run diagnostic check on your ignitor and tell you if its bad, I think. But I am not certain, since its a pr3, and idk what dizzy you are running. I don't know if that would be a problem.
Maldito X is offline   Reply With Quote
Old 08-30-2006, 01:18 PM   #3
yea I am obd0 I think it is td-22 or td-44 it's obd0, but thanks I am going to try to take to autoparts place and get it tested I dont think they do that around my way though..?
Old 08-30-2006, 01:22 PM   #4
I cleaned out my injectors and put new seals and still the same they are working though is there away to test them..? or tell? I think it is between the fpump and ecu though..
Old 08-30-2006, 02:09 PM   #5
Maldito X's Avatar
Yeah, I suspect its a problem with your dizzy,like the ignitor, I don't know what replacement there is for an obd 0 dizzy on ur b16, I'm not sure if you can mix and match, but why not go and find an obd0 ignitor off a b18 integra. Checker, kragen, autozone might run a check on ur ignitor, autozone offered to diagnose mine before buying. Is your tach needle bouncing around?
The Punk has me set on 10 posts a day limit, so if I have more to say, I will edit this post. Therefore read back on here to see if I respond, instead of checking for a new post from me.
Old 08-30-2006, 03:30 PM   #6
eudm_eg8's Avatar
i had the same problem on my d15b2 - when i pressed on gas pedal it bogged, if i floored it, it bogged like crazy.then one day my car wouldn't start up - there was no spark.my mechanic changed the ignition coil and now it works like new.
eudm_eg8 is offline   Reply With Quote
Old 08-30-2006, 04:55 PM   #7
saikouEF8's Avatar
check your thermostat ground wire. if not that then check coil and igniter
saikouEF8 is offline   Reply With Quote
Old 08-30-2006, 06:47 PM   #8
CASTUDILLO01's Avatar
MAKE SURE YOU SWAP THE YELLOW/WHITE AND GREEN/WHITE WIRE ON THE TPS SENSOR THEY READ BACKWARDS IN A DUAL POINT SYSTEM THEN ON A MILTIPORT. FOUND THAT TO BE VERY COMMON ON SWAPS PEOPLE DID AND FORGOT TO SWAP THOSE WIRES AROUND. ALSO USE A JUMPER HARNESS ON THE DISTRIBUTOR BETTER THEN SWAPPING WIRES AROUND AND HAVE TO RUN WIRES TO THE ECU.
CASTUDILLO01 is offline   Reply With Quote
Old 08-30-2006, 07:35 PM   #9
I am going to check the ignition coil to double check..
Old 08-30-2006, 07:37 PM   #10
? I dont understand the car will bog if the tps is backwards, yel/white , gre/white. on the ecu?
Old 08-30-2006, 07:50 PM   #11
Mr. Giggles's Avatar
a wire on my map sensor was disconnected.. backfired and bogged like a bitch.
Mr. Giggles is offline   Reply With Quote
Old 08-30-2006, 09:05 PM   #12
mahatma's Avatar
cam timing a tooth or 2 off?
mahatma is offline   Reply With Quote
Old 08-30-2006, 09:09 PM   #13
SVOboy's Avatar
He was saying that if you didn't switch the tps wires when you did the MPFI wiring it will cause such things, I'm with him for now.
SVOboy is offline   Reply With Quote
Honda Civic D15b non vtec bogging out after engine swap scrappydoops Honda Civic / Del Sol (1992 - 2000) 9 05-30-2016 05:43 AM
D16 Bog Down 6k Schlitzjr Forced Induction 5 06-15-2011 02:01 PM
bad tps or other problems? jjep8704 Acura Integra 5 07-27-2008 12:33 AM
B16 wont rev past 3500 rpm, and almost bogs when I tap the gas..... Lucky-13 Honda Civic / Del Sol (1992 - 2000) 14 03-17-2007 06:54 PM
vtec not engaging bogs out like i'm hitting the barkes preppy79 Honda Prelude 27 06-20-2006 12:45 AM
Tags
1989, 1995, 89, bogging, bogs, camaro, civic, d15b2, driving, floor, floored, flor, gas, integra, pressed, when
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
