Can you use a test light to test injector pulse?
Re: Can you use a test light to test injector pulse? (psycho.chicken)
i dont think so cause a test light works with 12v and i doubt the fuel injectors are 12v. what you do to see if your fuel injectors work is start the car put a long screw driver on the top of the injector then put your ear on the handle and listen for a ticking. no ticking means its broke.
Location: I told you to wait in the truck in Texas, United States
You can,But it will be really dim..
I have used a 194 light bulb before but it would
probably be best if you used a 6 volt lamp or a meter..
Re: Can you use a test light to test injector pulse? (88DXCRX)
I take them out and touch a wire to the negative terminal and one to the positive terminal of a battery and see if they click.
civic_driver09a
Audio / Security / Video
25
11-16-2009 11:41 AM
E.Honda
13
10-25-2006 08:42 PM
