can you remove the plastic back piece from the headlight ?
Old 11-02-2013, 09:51 AM
crxaddikt's Avatar
Default can you remove the plastic back piece from the headlight ?
(my car is 90crx, ),
i was wondering if you can seperate the plastic back side piece of the headlight, so it comes off the glass headlight part ? or is that part of the whole main headlight assembly ? where its permenantly attached to each other ?
my driver side headlight has a broken piece that goes on the back plastic part which is where one of the adjusting oval things screws into, so without it, its all loose and wobbly.
so i wanted to see if i could just get some cheap priced used crappy headlight and just use the back plastic part, and put it onto my headlight, which is in good condition.
Old 11-02-2013, 10:00 AM
NaturalTone's Avatar
Default Re: can you remove the plastic back piece from the headlight ?
pre heat oven at 360 then bake for 3/4min and take them apart.. i did it with my ctr lights when all the clips was broken and replaced the backs
Old 11-02-2013, 10:02 AM
Freemananana's Avatar
Not sure on the time or temp, but this is the method I've seen used.
Old 11-02-2013, 11:34 AM
Spug's Avatar
I'm not saying that NaturalTone is wrong, but 360° seems high to me. I'd start with a lower temp and just see what happens.
Old 11-02-2013, 04:34 PM
crxaddikt's Avatar
i did'nt think of that, at least there is a way to seperate and take that part off, well if i do that i'll be sure to just use a lower bake setting to be safe and see how it works, and if needed i can always do again with higher temp.
do you know if the headlight assembly from any other EF civic models fit the crx and use the same headlight ? thanx
Old 11-02-2013, 04:39 PM
crxaddikt's Avatar
i also have a heat gun, so i can maybe try using that also, to heat it, softening it to seperate that piece ?
Old 11-03-2013, 10:28 AM
Pretty sure that will work. It's the same as the oven method except safer in my opinion.
HaRrYbOy
Honda Motorcycles
01-02-2006 09:45 PM
petrv
05-06-2003 10:11 PM
crXtreme_girl
09-17-2002 04:23 PM
fast-R
08-03-2001 10:00 AM
Quick Reply: can you remove the plastic back piece from the headlight ?
