Can I jb weld my tranny casing?
Old 10-31-2006, 03:03 PM
rmnS2K's Avatar
Default Can I jb weld my tranny casing?
I was driving down the read today and hit a little rock with my tranny, when I got home and got out of the car I saw a oil leak. Turns out my b16 ys1 tranny fluid leaked out. I found a 2 inch crack in the casing.
Can i use jb weld or has anyone here jb welded a casing before. What other products are out there that i can use for a quick fix. I have a spare casing just dont have the time to pull out the tranny right now becasue this is my work car.
Old 10-31-2006, 05:22 PM
BlueCrxNC's Avatar
If I were in this situation I would rough the case up with sandpaper at the crack and JB Weld it temporarily until the weekend comes around to change the casing out. Check the oil level daily... put a fresh piece of cardboard under the tranny every night to help you keep up with the leak each day until then.
Old 10-31-2006, 05:27 PM
Pirate General...YARRRR
Ass$nyper's Avatar
Default Re: (BlueCrxNC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueCrxNC &raquo;</TD></TR><TR><TD CLASS="quote">If I were in this situation I would rough the case up with sandpaper at the crack and JB Weld it temporarily until the weekend comes around to change the casing out. Check the oil level daily... put a fresh piece of cardboard under the tranny every night to help you keep up with the leak each day until then.</TD></TR></TABLE>
I would agree with you there.
I've seen JB weld do some pretty amazing things, namely hold a tractor motor together for half a summer.
Old 10-31-2006, 05:42 PM
EFM_ookie's Avatar
Default Re: (Capt. Blonde Beard)
my tranny is about 50 percent JB weld!!! lol done professionally by a shop... hasnt leaked since, and that was almost a year ago JB weld
colnago's Avatar
Default Re: Can I jb weld my tranny casing? (rmnS2K)
I used JB weld on my tranny after cracking a hole in it removing a stuck drive shaft. The JB weld has hold up for 2 years now with no leaks. When you do it make sure crack is completely dry, no tranny oil, scrub crack with sand paper or 3m pad, clean area, then wipe with acetone to remove all traces of oil, apply jb weld. I let my transmision sit over night to cure then add tranny oil.
Good luck!
Old 10-31-2006, 09:44 PM
IndySporty's Avatar
Yeah I had the rear mount break off my CRX trans once.... it pulled the bolts and aluminum with it from the rear of the trans, and I JB welded it back together then bolted that mount back on and it held typical rollback/gear snatching abuse another few months before I got rid of the car! lol.....
Old 11-01-2006, 02:37 AM
nickeynick's Avatar
i've JB welded my casing i had it like that for about 1 1/2 months. then swapped the tranny the JB weld held great. make sure to clean it really good and drain every drop of fluid! good luck
Old 11-01-2006, 08:24 AM
andrey320's Avatar
You hit a "little rock" eh?
Old 11-01-2006, 10:13 AM
Death_to_Thieves's Avatar
try JB weld. you have nothing to lose. If it works then great if not, then time for plan B. Good luck
Old 11-01-2006, 10:46 AM
ryan89crx's Avatar
JB weld fixes everything, lol
Old 11-01-2006, 11:37 AM
turboZChatch's Avatar
Default Re: Can I jb weld my tranny casing? (8000KReV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8000KReV &raquo;</TD></TR><TR><TD CLASS="quote">try JB weld. you have nothing to lose. If it works then great if not, then time for plan B. Good luck</TD></TR></TABLE>
sp00ledbseries
Welding / Fabrication
05-07-2009 12:20 PM
Nameless Warrior
30
12-05-2006 09:56 AM
92hondalude
01-10-2005 11:19 PM
eluder33
12-19-2004 01:21 PM
TypeR1558
01-27-2004 04:03 PM
Quick Reply: Can I jb weld my tranny casing?
