cable too tight?
cable too tight?
got a small issue guys I got a 91 civic with a obd0 b16 installed by me I'm using the 91 Integra clutch cable it barely fit on the transmission but worked after I got it on the clutch engages when the pedal is almost completely retracted so I decided to tighten it up little bit now I'm grinding when I go into reverse and it feels a little bit harder to shift into gears not as smooth as before could the cable be too tight? also is my clutch bad because on my 03 Civic getting gauges a lot closer to having the pedal pushed the floor?
InJ3cted
05-24-2005 02:16 PM
