Old 03-25-2015, 12:38 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Lighting
Print Wikipost
Brake lights stay on...how I fixed them
Old 09-18-2009, 09:51 PM
  #26
apekd's Avatar
Default Re: Brake lights stay on...how I fixed them
Nice job man. For once a DIY repair that has the PART NUMBER in it. Props to you man.
Old 11-29-2009, 06:33 PM
  #27
New User
3rdiopen's Avatar
Wow! amazing write up, the exact same thing happend to me tonight, after about 5 minutes of searchings threads i found yours, 97SS. fixed the problem in 2 minutes with 2 pennies and some electrical tape. Thank you for the time spent on the DYI write up and everyone else that contibutes the to the treasure chest of knowledge on the forum.
Old 11-29-2009, 07:11 PM
  #28
crxmadness's Avatar
+1
Old 11-29-2009, 07:29 PM
  #29
Syper's Avatar
lol well now I know why 2 of the brake lights turn on and why I found that little pointy mysterious thing by the pedals.
Thanks for this, and thanks to 3rdiopen for bring it up!!!
Old 11-29-2009, 09:20 PM
  #30
hatchet_honda's Avatar
Default Re: Brake lights stay on...how I fixed them (97SS)
Originally Posted by sleepa
thank you for the help..i do however have a few questions..i indeed found the broken stopper pedal plastic piece part..and i was wondering..its plastic..if i get another one and replace it..how does that make the lights go off..i mean all it does is juzz there..and the brake switch..i notice that there is a white piece sticking out..well on mine..i dont see that piece..and the stopper pedal piece..can i get it at carquest or does it have to be from honda??
the plastic stopper covers the hole in the pedal so when you release the brake it pushes against the switch and turns the lights off.
Old 03-08-2010, 11:51 AM
  #31
TRIAL USER
mnpd's Avatar
Wish I'd searched and found this in the beginning. My trusty old '88 Civic LX had the "brakelight forever" problem. I assumed it was the switch and went the NAPA $20 route, and was puzzled. Fuseblock check, unhooking wires, bulbs, checking harnesses... a couple hours of work until I found this nice thread.
I didn't go back to NAPA for the missing pad (although I did find the remnants of the old one in the floorboard). I used a short bolt with lockwasher and nut without grinding the head down. I simply adjusted the ample length of the brakelight switch threaded shaft and used the locknut to lock it in place. It's adjusted right where I want it.
Now, if I could just stop this car from eating a rebuilt distributor every 6 months. Advance Auto has to eat it actually, since I bought the original one under the lifetime warranty.
Old 04-07-2010, 08:21 PM
  #32
philter8's Avatar
dude, i know you posted this 2 years ago, but it is absolutely the best blog post i have ever seen in my life. i knew there was a problem with my integra, because the brake lights wouldnt go out unless i pushed in the switch. but then i couldnt figure out why there was a friggin' hole in the brake pedal. on my way to the dealership to get a new one tomorrow, thanks again.
philter
Old 06-11-2010, 12:29 PM
  #33
lil' man's Avatar
anyone have or know where a write up is of the switch itself and how to replace IT?
Old 06-11-2010, 07:52 PM
  #34
hasty91ef's Avatar
Yeah I just use a short bolt and nut. Quick and simple and no problems.
Old 08-16-2010, 07:56 AM
  #35
AreaKode559's Avatar
This is so very helpful, I was wondering what that pointy blue thing was on my floor carpet!!! I'm glad you posted pics with it aslo !!!! 2 Thumbs up!!!
Old 08-19-2010, 11:22 AM
  #36
97SS's Avatar
Hey thanks for all the props guys. I know it's overkill with the pictures on such a simple fix but I always prefer pictures to long worded or short worded explanations. I'm glad this has helped out a lot of you guys the hassle of figuring it out or spending hard earned $$$ on non-repair parts like the switch.
I like the idea of pennies and what not but in the end I prefer the right part going in. I think if you measure or take your old piece over to a hardware store they probably sell the same/similar cap thing for a lot less.
Old 08-19-2010, 11:33 AM
  #37
WigginsSiR's Avatar
now all i need is to figure out why my reverse lights don't work?
thanks for good info
Old 08-19-2010, 12:34 PM
  #38
2 rex nelson's Avatar
This is a really great write up. This is what we should all do if we can. FYI that piece is also on your clutch. It broke on one of the rexs and I couldn't figure it out either till I reached under my pedal. I changed starters and ignition switches and nothing. Finally I felt the switch on the clutch and sure enough it started right up. I will try the bolt nut combo next time. Which bolt did you use?
Old 08-19-2010, 12:40 PM
  #39
egyolk's Avatar
thanks for the write up, good info
Old 08-29-2010, 05:27 PM
  #40
asocallocal's Avatar
this is the same exact thing that just happen to me. thanks for the write-up
Old 09-02-2010, 09:04 AM
  #41
jmyluck's Avatar
Thanks for the write-up. After reading it, I went to the nearest hardware store (ACE) and bought an auto trim grommet for 69 cents. Did the job! I had been most worried about getting pulled over by the fuzz for those damn brake lights being on all the time.
Old 09-02-2010, 09:16 AM
  #42
Black R's Avatar
Bam!!
http://eastcoastefcivics.com/index.php?topic=1440.0
Old 09-04-2010, 11:44 PM
  #43
90dohczccrx's Avatar
yea i had the same problem except it happened to the one on the clutch and i spent 2 weeks tryin to figure out why my car wouldnt start
Old 09-27-2010, 01:25 PM
  #44
coupkb's Avatar
Can someone please indicate as to how this little braked stopper pad can be installed? I tried just popping it back into the hole, but there is no space for me to pop it back in. Do we need to do anything to the brake switch to create space so that we can pop the pad in?
Thanks
Old 09-27-2010, 03:06 PM
  #45
Tyson's Avatar
push the brake pedal down so it reveals the hole.
Old 10-16-2010, 12:59 PM
  #46
journeyquest's Avatar
Thanks for the pics and solution to this problem.
Old 10-21-2010, 10:42 PM
  #47
johnnyboy2112's Avatar
Man you guys are awesome!!! I'm out of town and my wife just called me at 2am in the morning about her brake lights being on. (This crap always happen when I happen to go out of town)
She has a 2001 honda civic and it was exactly what you guys posted in the blog. The pictures were perfect. I told her exactly what to do and she super glued a quarter on there and it worked!!!
Thanks a million.................
Old 10-22-2010, 04:04 PM
  #48
Psycho719's Avatar
Haha damn bro same exact story. This just happened to me, so I googled it and found your thread! Thanks man! Luckily I had one of those break pedal stoppers sitting around. Would have never knew what the issue would be.
Old 10-22-2010, 11:15 PM
  #49
socialistic's Avatar
This happened to me on my DB1. Instead of ordering a new plug from Acura, I super-glued a penny over that hole. Problem solved, cost me $0.01 and some super-glue I found in my shop.
Old 10-25-2010, 09:28 AM
  #50
jruiz094's Avatar
lol this happened to me last week so i put taped tiny rock on the pedal so it can hit the switch.
Quick Reply: Brake lights stay on...how I fixed them
