Bottom D16Y7 non-Vtec with Top D16Y8 Vtec. - Honda-Tech
Old 03-18-2010, 05:01 PM   #1
bmanuhutu's Avatar
Default Bottom D16Y7 non-Vtec with Top D16Y8 Vtec.
Will these work?
Right now my 91 civic DX running D16Y7 non-vtec with PM6 ECU and SI tranny.
Short story, somebody wants to give me D16Y8 VTEC head,.
Now will these work? or do I have to get new ECU? If it does, what ECU do i need?
Also do i need anything else to make these work?
Many thanks.
bmanuhutu is offline   Reply With Quote
Old 03-18-2010, 05:12 PM   #2
Keyboard Humorist
4drEF's Avatar
Default Re: Bottom D16Y7 non-Vtec with Top D16Y8 Vtec.
Search for MINI-ME
Yes, that combo will work.
You would want to use an ECU that has vtec control because the PM6 doesn't do it.
OBD0 PR3's, OBD1 P28, or any OBD1 converted to support vtec (P04).
Best would probably be the P28 since the fuel maps are going to be pretty close right out of the box.
You will need to convert to OBD1 if you use an OBD1 ECU.
4drEF is offline   Reply With Quote
Old 03-18-2010, 05:30 PM   #3
SugarsEK's Avatar
very popular swap .. easy swap
use you stock y7 throttle body ...and swap over the throttle cable rotor from the y8
you will need to add some wires .. there are great d.i.ys all over the net
SugarsEK is offline   Reply With Quote
Old 03-18-2010, 05:39 PM   #4
Eaglekper0046's Avatar
Quote:
Originally Posted by 4drEF View Post
Search for MINI-ME
The only problem with the P28 is the timing maps are different. Y8 has a totally different combustion chamber compaired to other d motors. It will run but not perfect.
Eaglekper0046 is offline   Reply With Quote
Old 03-18-2010, 05:41 PM   #5
Why would you use a Y7 throttle body for an ECU that reads a 2 wire IACV?
ZC sohc non vtec help Ek4drcindy Honda Civic / Del Sol (1992 - 2000) 2 03-24-2011 01:29 PM
Please help... bmanuhutu Honda CRX / EF Civic (1988 - 1991) 5 04-05-2010 02:25 PM
Need help asap!!!! D16y7 non-vtec to d16y8 vtec 00_civic757 Honda Civic / Del Sol (1992 - 2000) 3 01-29-2009 03:29 PM
d16y8 swap to a d16y7 non-vtec khmaiabz Honda Civic / Del Sol (1992 - 2000) 5 10-04-2008 03:12 PM
d16y7 inter-changable with d16y8???? trimugenhatch Honda Civic / Del Sol (1992 - 2000) 4 09-19-2007 09:30 AM
Tags
build, convert, d16y7, d16y8, ecu, ef, engine, good, honda, mini, sale, swap, tech, vtec, y7
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
