bosch vs ngk/ntk o2 sensor
Old 02-06-2013, 06:15 PM
vtec8200's Avatar
Default bosch vs ngk/ntk o2 sensor
Hi, my 90 si has hesitation/stutering at constant speed until the check engine comes on, then all is fine. CEL code is 1 (oxygen sensor). There does not seem to be anything wrong with the wiring.
I am looking through ebay and found the ngk/ntk brand and bosch brand, and I remember seeing comments about certain o2 sensors that made the car run like crap even if the part was brand new so I would like to get peoples opinion on this,
Also, can my bad o2 sensor cause a fluctuating idle? idle goes up to 2000rpms for maybe half a second then drops back down and up again. I have cleaned the IACV thoroughly (wasn't very dirty) and I have bled the coolant, was just wondering if a bad o2 could cause this.
thanks
Old 02-06-2013, 06:29 PM
vtec8200's Avatar
Default Re: bosch vs ngk/ntk o2 sensor
There is also Denso, which I know is usually good quality, 10$ more than the ntk.
Old 02-06-2013, 07:35 PM
90_EX_Civic's Avatar
when in doubt run ngk. denso is, if im not mistaken, a sister company of ngk
Old 02-06-2013, 07:55 PM
meda215's Avatar
bosch is one of the best oem parts manufacturer......all widebands use one of the o2 sensors from bosch
Old 02-06-2013, 08:15 PM
freddy chavez's Avatar
I had the same problem with my iacv and cleaned it and looked new but just wouldnt work.tried my friends iacv from his car and workes beautifull.my guess is u should just replace it like i did
Old 02-07-2013, 08:32 AM
CRX Toad's Avatar
Denso, NGK, Bosch in that order. I hate putting Bosch on a customers car because they just don't seem to hold up as well.
Old 02-08-2013, 06:45 AM
villc713's Avatar
bosch o2 sensors suck.......wideband o2 is another story.....get the denso or ngk
Old 02-09-2013, 05:49 AM
vtec8200's Avatar
got the denso!! thanks!
Old 06-11-2014, 01:39 PM
gabrielsousa's Avatar
thanks
i too have fluctuating idle, did you fix yours ?
jayman3.0
02-03-2008 05:07 PM
youngvedder
10-24-2004 12:42 PM
clutch33
08-04-2004 03:28 AM
97civicdx
09-03-2003 12:49 PM
IloveNewt
03-24-2003 12:53 PM
Quick Reply: bosch vs ngk/ntk o2 sensor
