best way to move fuel pump
ok im fixing to change fuel pump witch way would be better just drop the tank or is there another way to do it i have a 90 crx si with a b18swap puting a bbk fuel pump in tank
Re: best way to move fuel pump (90si_mugen_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90si_mugen_crx »</TD></TR><TR><TD CLASS="quote">cant u take the rear inter out and get to it seems like u can not sure what kinda fuel pump should u run </TD></TR></TABLE>
No, I think the fuel pump is farther back if I rememember correctly. The size of the pump that you will need will depend on what is done/planned for the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90si_mugen_crx »</TD></TR><TR><TD CLASS="quote">the motor is stock has header and cold air intake </TD></TR></TABLE>
I wouldn't worry about the fuel pump, the stock one should be more than sufficent. I ran 12-14 psi of boost from a 60 trim t3 with the stock pump and was still able to see low 11 AFR's.
Re: best way to move fuel pump (96-EJ6 B18C)
well somethings wrong then it runs good at idel and runs good if i rev on it a little but if i dive it i cant even press the gas half way it starts cuting out if i nail the gas it will just go dead i can let off the gas after i nail it and it will start up agin it runs good dont miss or smoke the guy that did some of the motor tunning said that i need a fuel pump
Hmmmm....
It is really hard to say but I'd check the fuel filter, cap, rotor, plugs and wires before anything. Are you getting codes?
i put new plugs and wires also put a new fuel filter when i put it on and ran it it run good for a few hours i could get on it good and it ran good think it might be picking up some trash from the tank like i said it ran good for one day then after that it started running shity agin far as codes go its the o2 censer code but that cant be the prob or can it
trooper0641
23
04-06-2005 12:51 PM
