Best Engine Oil Weight for high mileage EF? - Honda-Tech
Old 10-24-2009, 10:42 AM   #1
Location: Boca Raton, FL, for now, will be relocating tot eh Raleigh, NC area in the next few years.
Default Best Engine Oil Weight for high mileage EF?
My local Advance said I needed 20W50!! I was thinking 10W30 or 40, am I crazy? This is for a stock D16 with 210K miles on it. 20W50 seems a little too heavy to me!! What weight oil do you guys run? This is just a stock A to B car, no racing. Thanks!
Jerry
90EFCruiser is offline   Reply With Quote
Old 10-24-2009, 10:49 AM   #2
gibsanez's Avatar
Default Re: Best Engine Oil Weight for high mileage EF?
10w40 will be fine unless it's burning oil like crazy right now
gibsanez is offline   Reply With Quote
Old 10-24-2009, 10:52 AM   #3
Thanks for the quick response! It's not burning oil at all, great running little car! I think it;s leaking a VERY SMALL bit by the dizzy, but, that's it. Again, thanks!
Jerry
Old 10-24-2009, 11:23 AM   #4
BiG ChOr!Zo's Avatar
im using 20w50 as well...!!!
BiG ChOr!Zo is offline   Reply With Quote
Old 10-24-2009, 01:01 PM   #5
Im at 175,000 and still using 5w30. Why would you need to even run anything heavier than that?
ninety1Dseries is offline   Reply With Quote
Old 10-24-2009, 01:31 PM   #6
DCRB's Avatar
just use what honda suggests, which is 5w30.
DCRB is offline   Reply With Quote
Old 10-24-2009, 02:02 PM   #7
blasterman87's Avatar
heaver oil isnt really useful imo, ive also heared that it can work the oil pump harder and lead to falure.
blasterman87 is offline   Reply With Quote
Old 10-24-2009, 03:07 PM   #8
HybridHatchEF9's Avatar
my B2 has over 350,000 miles on it and still running strong! smokes a lil but hey its a 91! with stock internals...
Royal Purple 5w30 boi!
HybridHatchEF9 is offline   Reply With Quote
Old 10-24-2009, 03:19 PM   #9
sde780's Avatar
34w12 only pamper
sde780 is offline   Reply With Quote
Old 10-24-2009, 03:46 PM   #10
Rainman
SIred91's Avatar
Royal Purple has been proven to be **** by the way.....FWIW.
Just use what the manual recommends OP. 5w or 10w30
I use 10w30 in the summer adn 5w30 in the winter
SIred91 is offline   Reply With Quote
Old 10-24-2009, 04:19 PM   #11
DO IT ON ALL FOURS
OneBadTurboCRV's Avatar
X2 on both aspects.
OneBadTurboCRV is offline   Reply With Quote
Old 10-25-2009, 06:42 AM   #12
gibsanez's Avatar
If OP still is living in FL he doesn't have a winter.
Old 10-25-2009, 08:21 AM   #13
Charlie Moua's Avatar
i normally use mobile 5-30
but recently got some free castor 0-30 and my motor feels much better.
Keep in mind that I only drive my ef gsr 3 months out of the year (4K) and the motor only has 50k on it.
Charlie Moua
Charlie Moua is offline   Reply With Quote
Old 10-25-2009, 09:03 AM   #14
Vietnamese!
ALLxMOTOR EG's Avatar
I myself usually use Mobil 1 5w-30 over the past year in my crx with 178k.
No problem whatsoever.
ALLxMOTOR EG is offline   Reply With Quote
Old 10-28-2009, 01:43 AM   #15
yee510's Avatar
im using 5w-30 in my ef wit 288k, nd still runnin good.
yee510 is offline   Reply With Quote
what oil brand and weight to use??? Integra303 Acura Integra 9 07-19-2009 10:45 AM
Mobil 1 and Oil weight question: 03 2.4L keilux Honda Accord & Crosstour (2003 - Current) 16 07-09-2009 05:24 PM
What oil weight should I use? islnder102 Honda CRX / EF Civic (1988 - 1991) 8 10-12-2006 07:45 AM
Using wrong oil weight TURBL0W Tech / Misc 5 11-28-2004 09:42 PM
whats the difference in oil weights? drewbie Honda Civic / Del Sol (1992 - 2000) 2 09-11-2004 09:32 PM
Tags
09, 2001, 2002, 20w50, accord, acura, civic, high, honda, mile, mileage, motor, oil, recommended, tl, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
