bench bleeding master cylinder? - Honda-Tech
Old 11-15-2008, 01:37 AM   #1
801ef's Avatar
Default bench bleeding master cylinder?
ive read on it and ive searched on it but i dont fully understand how to , ive read that u have to push the rod back and forth gently but does the master cylinder have to be on the brake booster? pics would be awsome but any step by step would be great to
801ef is offline   Reply With Quote
Old 11-15-2008, 01:50 AM   #2
$cat /dev/urandom
sanimalp's Avatar
Default Re: bench bleeding master cylinder? (801ef)
bench bleeding can be done in the car.. its probably easier anyway. you have to put the resovoir on and fill it up, then run some rubber hose from the output back to the resovoir. just pump it until you stop seeing air coming out. you might also want to put a towel under that, unless you don't like paint on your car very much.
sanimalp is offline   Reply With Quote
Old 11-15-2008, 08:25 AM   #3
I have bench bled a master cylinder all of 2x in my life. It is pretty easy to do on the bench. Here is a pretty good online guide: http://www.tegger.com/hondafaq....html
I bought my master cylinder remanned at Napa.
honda.lioness is offline   Reply With Quote
DA Brake Master Cylinder Swap j3wman Honda CRX / EF Civic (1988 - 1991) 8 06-27-2012 04:16 PM
are 90"crx hf brakes that bad? neozero999 Honda CRX / EF Civic (1988 - 1991) 14 04-14-2008 04:03 AM
88-91 hydro conversion using clutch master cylinder from 92+ civics alpha_1 Honda CRX / EF Civic (1988 - 1991) 4 02-11-2008 11:43 AM
Master clutch cylinder removal jivi Honda Civic (2001 - 2005) 16 09-18-2007 06:59 AM
clutch master cylinder going bad? itsJDMyo Acura Integra 2 10-24-2005 06:02 PM
Tags
86, 94, accord, bench, bleed, bleeding, cbr, civci, civic, crx, cylinder, honda, integra, master, prelude
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
