Ball Joints and Bushings
1 Post
Re: Ball Joints and Bushings
Not hard with the right tools. Need a press and various sockets, pipe fittings etc. You can rent or buy a kit with everything you need other then the press.
DO IT ON ALL FOURS
Press? You don't need one... Pipe Fittings? No, don't need them either... Regardless, you never said if you were wanting to replace the uppers, lowers, or all of them. The top is extremely easy as is the bottom. You can do the job without any specialty tools. If you wanted to use some to make it easier, it would be just snap ring pliers and maybe a "pickle fork". You asked how hard it was, not how to do it. Go and look at a repair manual and see if it's too much for you.
Then again, If you are asking I would just take it to a shop.
Very Easy! If you can't get them out with some good smacks, I've used a jack to get the bottoms out, tops usually aren't an issue. Pop out the old, put in the new, and do not forget the snap rings.
If you really have rookie wrenching skills you can buy the upper arms that come ready to install with all new hardware and ball joints. The lowers are easy, almost as easy as googling "crx balljoint removal"
Op are you asking how hard it is to replace them or remove and replace them?
No offense but if you cannot remove them I wouldnt attempt installing new joints yourself.
We aren't trying to discourage just being practical.
Cool thanx mostly I was just wondering about tools mostly. I'm a novice on a wrench but fully capable. Thanx again!
Ummm. Do you mean using the upper ball joints as lowers? As far as I know S2 does not make lower ball joints just the upper. Try moog for the lowers and avoid unknown balljoints from shady eBay sellers. Napa is pretty good also albeit all made in china...
Ok now I got the lower ball joint on the driver side free no problem, but on the passenger side it won't give. I've tried ta hit it out of the control arm and nothing. Any suggestions??
Pancho2193
03-11-2011 05:10 PM
PatrickGSR94
Suspension & Brakes
18
05-12-2010 09:55 AM
jdmwannabee
09-13-2009 06:34 PM
