bad throwout bearing?
Old 02-26-2009, 06:43 PM
spens 91 Ef's Avatar
Icon2 bad throwout bearing?
i just replace my clutch and my throw out bearing and its still making that beautiful grinding sound when you release the clutch i just replaced it, how can i fix it thanks
Old 02-26-2009, 06:57 PM
Default Re: bad throwout bearing?
any ideas
Old 02-26-2009, 08:06 PM
iwanttokillgod's Avatar
input shaft bearing
Old 02-26-2009, 08:16 PM
be professional
Targa250R's Avatar
You replaced the wrong bearing.
A bad clutch release bearing will only make noise with the clutch pedal pushed in, because that's the only time it spins.
Bearing noise with the clutch pedal out in neutral is caused by the mainshaft bearings. Typically the inboard bearing is the culprit, but the outboard bearing can occasionally cause some noise.
Solution: Open the trans case and replace the inboard mainshaft bearing (also called the "input shaft bearing") and the main seal behind it. Do it before the bearing fails completely and damages the mainshaft and the case. Check the outboard bearing while you're in there and replace if it is rough or noisy.
Old 02-26-2009, 09:35 PM
89s1's Avatar
Originally Posted by iwanttokillgod
input shaft bearing
winner
Old 02-26-2009, 09:36 PM
89s1's Avatar
bigger winner
Old 02-27-2009, 04:14 AM
Reject Papi
jhammond_82's Avatar
i gots to change that in my ys1 transmission. its not to costly of a project. about 90 bucks for the part. and i can get it done for 150 bucks or so. its a small price to pay when you can double the life of your transmission.
Old 02-27-2009, 05:22 AM
be professional
Targa250R's Avatar
An input shaft bearing is $36 or less and the main seal is $6.xx. You'll need 3 quarts of MTF at $7ish per quart. That's a grand total of $63 in parts for the entire job provided that nothing else is needed.
Old 02-27-2009, 05:55 AM
Reject Papi
wow, where can i find prices like that? i've looked, and the best i can find is 45 for the bearing and 45 for the seal kit. you're in pittsburg, can you fix my transmission if i brought it to you? damn, me and my thread jacking, lol sorry!
Old 02-27-2009, 06:03 AM
rustbucketrex's Avatar
Honda Parts Unlimited. I just bought the bearing for $18.77 and the seal for $4.20, along with some other stuff. You will also have to pay shipping, so it is best to figure out everything you might want to order at one time so you are only paying one shipping charge.
Old 02-27-2009, 07:11 AM
Reject Papi
now, thats for a d series trans correct? i went to syncrotech and they emailed me a quote of 90 for both, plus shipping. mine isn't for a d series though, its for a ys1 (b16) trans.
Old 02-27-2009, 08:06 AM
be professional
Targa250R's Avatar
Any Honda or Acura dealership.
The correct bearing and correct main seal will depend on the transmission model, but I haven't seen an OEM inboard mainshaft bearing that listed for more than $36.
Old 02-27-2009, 10:58 AM
Sorry about that, yes the prices I gave you are from a D series transmission.
Old 02-27-2009, 05:41 PM
well i just pulled my engine out so the oil is brand new, would it be easy enough to do i know about hondas just not a whole lot havent ever taken apart a tranny but pulled a engine out
Old 02-27-2009, 05:49 PM
2slow4stock's Avatar
Cable d series trannys are cheap. A dime a dozen.
Old 02-27-2009, 05:52 PM
Grnnt4's Avatar
Take it apart just to see if you can do it. I've never been that deep into a Honda, either, but I'd try before I paid someone to do it for me.
Old 02-27-2009, 05:56 PM
ya i might give it a shot and keep my out for a si tranny, im not driving it right now so its not a big deal
Old 02-28-2009, 09:45 AM
be professional
Targa250R's Avatar
The YS1 takes a 91002-PS1-003 bearing, list price $36.33. The main seal is 91216-PH8-005 @ $6.33.
The Si D-series transmission takes a slightly smaller 91002-PS0-003. It's $24.72 for an NTN bearing from Honda.
The non-Si D-series trans takes a smaller bearing yet, 91002-PHR-003 @ $22.48.
Both Si and non-Si D-series transmissions take the same main seal, 91216-PL3-005 @ $6.85.
Not anymore.
Especially good Si transmissions.
You used to be able to pick them up left and right for $150. Now you have to hunt for one, pay up a good amount, and hope it doesn't have major problems.
If you can pull an engine, you can replace an input shaft bearing. There are several write-ups on this procedure floating around the internet. I'd suggest buying a Helm factory service manual if you don't already have one; they thoroughly cover torque order and specs, and disassembly/reassembly procedures.
Old 02-28-2009, 02:18 PM
dangmedcalf's Avatar
sounds like i did the same thing, i replaced the throw out bearing first, looks like i need to replace the input shaft bearing before my h22 lsd tranny is destroyed
Old 02-28-2009, 04:50 PM
Reject Papi
awesome TARGA!! now i have a part number to go with. maybe i'll try this at home too. thanks alot!!
Old 03-01-2009, 11:18 AM
the helms manual was the first thing i bought for my car lol its my bible
Old 03-02-2009, 08:14 AM
where should i buy these at
Old 03-02-2009, 08:27 AM
be professional
Targa250R's Avatar
A dealer.
Old 03-02-2009, 08:55 AM
you know if the online honda parts store sell them
Old 03-02-2009, 10:53 AM
be professional
Targa250R's Avatar
Of course.
Check on the shipping first though. You may or may not be saving money.
Quick Reply: bad throwout bearing?
