BAD MAIN RELAY
Old 12-16-2005, 07:30 AM
joewho76's Avatar
Default BAD MAIN RELAY
Whats good im about to buy a ef with a bad main relay or so the owner says, is it an easy fix?, can i go to my local junkyard and find one and swap it in. lemme kno? thanks
Old 12-16-2005, 07:42 AM
be professional
Targa250R's Avatar
Default Re: BAD MAIN RELAY (joewho76)
Yes, it is a common problem and an easy fix. I wouldn't get a used one, as it is likely to have problems also. New ones are about $35-40. Or, if you know how to solder, you could fix it yourself with one of the DIY write-ups that you can find by searching.
Old 12-16-2005, 07:45 AM
joewho76's Avatar
Default Re: BAD MAIN RELAY (Targa250R)
Im thinking about gettin one from a junkyard just to last the ride home then buy a new one, what you think
CRX Toad's Avatar
Targa is correct solder it or buy new. Don't waste money at junkyard unless you absolutely have to.
Old 12-16-2005, 08:01 AM
joewho76's Avatar
Default Re: BAD MAIN RELAY (CRX Toad)
How much should i be expecting to pay new, easy install correct?
Old 12-16-2005, 09:00 AM
crxtreme89h's Avatar
Very easy install and you should pay approximately $40-$60 new.
Old 12-16-2005, 09:29 AM
Craigp23usa's Avatar
56 for mine from honda. one bolt and a plug. do you know where it is?
Old 12-16-2005, 10:17 AM
joewho76's Avatar
Default Re: (Craigp23usa)
Its under the steering wheel somewhere correct? Does honda have to order this relay or should any dealer have one....good looks
Old 12-16-2005, 10:18 AM
vegaskurt's Avatar
Do it yourself, its simple.
If your sitting in your car, its on the kick panel right around where your left shin would be on the left side. You can pull back the plastic part of the interior just enough to see it. Do a search for pics so you know what it looks like.
Then one bolt and it pops out.
I took a solder iron and heated up each joint (carefully!) and applied just a touch of new solder to each joint. Technically you only need to do this to the dry joints to fix the problem but I did them all. Since then I have never had a starting issue.
Old 12-16-2005, 10:36 AM
you should just go to the dealer. if you find a parts store that carries it. they will just call up the dealer and make a lil profit.
DEALER ITEM
Old 12-16-2005, 11:17 AM
Old 12-16-2005, 11:58 AM
HiProfile's Avatar
Default Re: (crxtreme89h)
99% of the time, its just a cold solder joint causing the problems. Problems which are usually limited to failure to start (no spark) when the interior is warm/hot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> [img]Then one bolt and it pops out.</TD></TR></TABLE>
That's a bit decieving. Took me more than gravity for it to 'pop out'... Happened to mine, re-soldered each joint quickly - no issues since.
JusAccord
01-25-2012 03:00 PM
88_hatch_ls
05-09-2011 08:36 AM
whiteformula98
08-03-2008 08:53 PM
4dohs4mohoes
11-24-2006 11:17 PM
dr_rod
08-11-2003 04:04 PM
Quick Reply: BAD MAIN RELAY
