ride hight problems :?
Old 04-05-2012, 08:14 AM
Bert01's Avatar
Icon3 ride hight problems :?
well got some rokkor coilovers (bad choice in my book) butttt if i got them i might as well ride them out alittle, problem is i set them all the same but the car comes out not even ?! ..this is wat i did i put the adjustable stops things at the bottom then turned it 12 1/2 up put it together and put it on the car and lower it but at the end the car is uneven all different hights ..wat am i doing wrong ?! sorry for the read .. thanks
Old 04-05-2012, 08:48 AM
90civic-ZC's Avatar
Default Re: ride hight problems :?
How are you measuring that you're car is at different ride height? Have you drove it around for a couple miles to let the shocks sink in?
Old 04-05-2012, 09:31 AM
TearSDMF89dx's Avatar
its a 20+ year old car things distort/move/settle over time could be any number of causes but only one solution decide on the height you want and adjust it accordingly at each wheel
Old 04-05-2012, 07:30 PM
Bert01's Avatar
i put the locking nut things on the last set of threads and counted up 12 1/2 .. is that the right or wrong way ? ..thanks ill try that see wat happens
Old 04-10-2012, 05:58 AM
BiGZ's Avatar
Remember that adjusting one corner of car affects the opposite corner (ie LF + RR,etc...)
Also teh weight of driver once seated! Between each adj,ride around to "settle" teh suspension. (Pros recommend best way is on tiles under all 4 wheels-with salt sprinkled in between them to allow them to "slip" on each other-less "riding around settling" that way),meh I just adjust em as needed since I LOVE driving,lol...
pr0gre551ve
Suspension & Brakes
05-17-2014 02:03 PM
acmoc
28
02-26-2008 06:05 AM
kixcrx
12-19-2006 12:13 AM
JTTeG_X
14
11-02-2005 07:04 AM
JSITR
06-27-2002 06:57 PM
Quick Reply: ride hight problems :?
