B20A1??? Does anyone know alot about this motor. - Honda-Tech
Old 12-20-2001, 12:14 AM   #1
Default B20A1??? Does anyone know alot about this motor.
I can get like a 88 or 89 prelude 2.0L for free... This car has a B20A1 in it.... can these be built for LS/Vtec?
EF-Civic is offline   Reply With Quote
Old 12-20-2001, 12:57 AM   #2
crxgurlllll's Avatar
Default Re: B20A1??? Does anyone know alot about this motor. (EF-Civic)
nope, the head dont match other b series...
crxgurlllll is offline   Reply With Quote
Old 12-20-2001, 05:08 AM   #3
EP3_05's Avatar
It is a b series and it was one of the worst ever made. It has a horrible rod/stroke ratio but it can be made to produce some nice power numbers. However, I do not think that it would be good for a "frankenstein" setup. I would suggest using an LS block or a newer B20 block from a crv. JMO
EP3_05 is offline   Reply With Quote
Old 12-20-2001, 10:19 PM   #4
New User
Default Re: B20A1??? Does anyone know alot about this motor. (91civic)
first that engine code should either be a B20a5 or a b21a1. and those motors are not as bad as everyone seems to think. i have not had any problems with them nor has anyone else that i know.
HOWEVER, if you want to put the engine in a civic or crx, that wouldn't be the best thing. the handling will be affected because of the large weight difference. the engine from the integra or the ls would be a much easier fit and a better choice for a civic/crx.
4wsB21a is offline   Reply With Quote
Old 12-20-2001, 11:14 PM   #5
Default Re: B20A1??? Does anyone know alot about this motor. (crxplus)
Yeah bad choice if your going to put that in an EF, if you want the frankenstein motor I would stick w/an LS or a newer B20.
SiREF8 is offline   Reply With Quote
Old 12-23-2001, 01:35 AM   #6
KS-R's Avatar
Default Re: B20A1??? Does anyone know alot about this motor. (SiREF8)
Apparently.. these older Prelude motors can be converted to LS/Vtec there's a site that does it. Check it out.
http://ludicrous2_0.tripod.com/vtec/
But.. I think it'll be a mounting nightmare for an EF.. a later model B series would be simpler especially with all the kits that are available nowadays.
KS-R is offline   Reply With Quote
Old 12-23-2001, 12:41 PM   #7
New User
hey friend, don't even bother wasting any time or money on that motor
that has the worst rod ratio out of all b-motors of all time!!
look for a B20z if your going to leave pistons and rods stock if your going to change rods and pistions then you can use either the the other b20 out of the earlier CRV or the newer one the Z has a higher comperssion
but what ever u do DON'T use the B20a1 out of the prelude
power4civic is offline   Reply With Quote
b20a5 or b21a1 b1620psi Transmission & Drivetrain 3 07-31-2010 02:47 PM
****MEGASALE: EF parts GALORE,S2K,S20,Z6,Skunk2,H22,GSR,B16,OEM**** Pinja For Sale 27 06-08-2009 01:15 PM
95mm crank from b20a1 in b20b bzyq2001 All Motor / Naturally Aspirated 3 08-12-2008 11:41 AM
Nyce1s.com....NHRA Sport Compact Nationals Event Videos (SPFWD) included!! nyce1 Drag Racing 17 05-11-2007 03:32 PM
H23A1 Venom Intake Manifold ralpheezy Honda Prelude 14 03-14-2005 06:06 PM
Tags
b20a1, crx, engine, frankenstein, honda, kits, motor, owners, prelude, problems, sale, swap, transmission, vtec, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
