b20 swap on crx need help on wiring
i did a swap on my crx put a b20 im using a wiring harness that came out from ls DA integra and bought a od-0 to obd-1 jamper harness....the crx was originally efi carburator with the DA harness is it gonna plug and play or do i have to wire up anything else to the ecu?
Keyboard Humorist
If I read correctly, his stock harness is for a carb engine... not fuel injected.
I think you are going to have to do a lot of wiring so it won't really matter what engine harness you use. Any way you go you will have to make your own sub-harness to go from ECU to engine bay. You probably won't even need that 'preOBD to OBD-1' jumper harness since you will be wiring from ECU to engine bay pin by pin.
It's not impossible - just get the wiring diagram for your ENGINE and be patient!
Or did I read wrong?
Maybe he meant that it's a DPFI engine when he said 'efi carb'?
If that's the case then YES - go get your stock engine harness and convert to MPFI and go from there as suggested by 'knightsef-eg'
B18C1_CRX
07-15-2006 03:35 PM
