B18b Vacuum Diagram? Confused...
I swapped a ls into my civic and i sent the harness to Rywire and when i got it back everything hooks up fine, and it starts fine to, but i have two sensors that don't arent hooked up and i dont know what the deal is with the vacuum lines, if i have them misplaced or what? It runs good, but i just wanna make sure that i have them right. Also i looked at this diagram below, but it doesn't have all the sensors that i have on mine, So if someone can post a pic of their vacum hoses that'd be great.. Thanx
The sensor you have circled is your MAP sensor, you hvae to plug this in. Your current map is the 3 wire sensor on your firewall, unplug it and plug it into the throttle body mounted map. You old map is now unused.
