B18a1 OBD0 EF Sedan Won't Start!!
So i have an 89 EF sedan with a b18a1 in it. the ecu is a Pr4 and it has an LS trans. The ignition is fucked so its wired to a push button. Anyways, i bought the car as a shell and it came with the motor so i bought a trans. I trust the guy so please dont tell me the motor is blown because it is not. it has compression just fine.
First of after everything was hooked up when i would push the button, the motor would turn over for about .1 seconds and then i found out that the starter wasn't getting enough amps. So i made a ground from the trans to the chassis and one from the vc to the core support which i should've had all along. So from there she was turning over and i got excited but it won't start. She is getting fuel to the fuel rail, just no spark. i had a buddy of mine come by and he rebuilt the distributor for me and still no spark. i've had this problem for 2 months and the car has been sitting. Any suggestions ?
Re: B18a1 OBD0 EF Sedan Won't Start!!
Did you run the extra wires to the dizzy or did the previous owner? You need to swap c1 and c2 to pins b10 and b12 on the ecu side and then with the now empty slots @ c1 and c2 run 2 new wires to the distributor for the ckps. Your buddy rebuilt the dizzy... Please Tell me he didnt just toss a cap and rotor at it and call it a day?
Trung Nguyen
13
02-24-2010 03:18 AM
