B16a Y1 haftshatf and axle problems??????
Old 06-15-2006, 05:18 AM
si90rex's Avatar
Default B16a Y1 haftshatf and axle problems??????
ok i finished my swap and im having issue turning but a friend of mine said that the axle is bound up and the axle in a jdm crx are shorter that a 90-93 integra. so is this true. if so do i need a halfshaft out of a 90-93 integra ls. or is there some way of shorting the one axle. both brand axle for a 90- integra if any one can help i would be greatful.
its jdm B16a w/lsd in a 90crx si
thanks
Old 06-15-2006, 05:20 AM
CRXBart's Avatar
Location: Land of the free, whoever told you that is your enemy
Default Re: B16a Y1 haftshatf and axle problems?????? (si90rex)
depending on the intermediate shaft that came with the swap, the JDM crx intermediate shaft is longer. IF you switch to a 90-93 integra intermediate shaft it will fix your problem.
Old 06-15-2006, 05:29 AM
si90rex's Avatar
Default Re: B16a Y1 haftshatf and axle problems?????? (CRXBart)
that what i figured but i need to find the intermediate i was at the junkyard yestard day and there wasn't any 90-93 integras with motors every one has already toke the ls as a swap. i need a parts finder i also was told if i use a 94 gsr ls and use the axle and intermediate shaft it should work. i don't know about that though.
Old 06-15-2006, 05:37 AM
CRXBart's Avatar
Too bbad man I just sold jesterian a int. shaft a month ago. Check ebay.
Old 06-15-2006, 05:41 AM
si90rex's Avatar
good idea thanks for the help.
Old 06-15-2006, 05:42 AM
CRXBart's Avatar
NE time brother here to help!
hondaex99
11-24-2009 02:12 PM
BigSorn
19
10-23-2009 05:19 PM
aojtin
03-06-2009 12:26 PM
crxtech
03-29-2006 10:45 PM
iridebiketrials
06-10-2004 05:22 AM
Quick Reply: B16a Y1 haftshatf and axle problems??????
