ZC engine distributor number
Old 06-04-2014, 09:50 AM
JohnED7's Avatar
Default ZC engine distributor number
Hey guys, have a '89 civic si with a zc swap. Last week I went to go to work and the car would not start. It turned over but was not getting any spark. checked my plugs and they were fine. Also check the distributor cap and rotor, both of which i replaced and still not getting anything. Narrowed it down to the whole distributor. The problem is that I am having trouble finding the distributor's part number so that I may order the correct one. Can anyone tell me where that number is so that I may check, or can someone tell me the number that I need? Thanks so much for the help!!
Old 06-05-2014, 12:40 PM
PHANTOM MENACE
24TEN's Avatar
Default Re: ZC engine distributor number
Which specific ZC are you using?
Old 06-05-2014, 01:05 PM
Tyson's Avatar
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/zc-means-1-6l-d-series-3186610/
Old 06-08-2014, 06:20 PM
JohnED7's Avatar
The engine is a DOHC ZC that came in 1988-1991 civic or integra, that's as much as I know about it.
Old 06-09-2014, 08:42 AM
Tyson's Avatar
well thats a start....
contact jlicrx. he's the most knowledgeable on those engines.
Old 06-09-2014, 09:15 AM
xprometheusx's Avatar
Dohc zc only came in jap si and the dizzy would mostliekly be 88-89 integra. Or u can also use 88-91 usdm civic si dizzy.
Old 06-09-2014, 09:45 AM
PHANTOM MENACE
24TEN's Avatar
Originally Posted by xprometheusx
88-89 integra.
That's the one you want. Make sure you DON'T get the older 86-87 vacuum advance style one.
Old 06-09-2014, 09:48 AM
Keyboard Humorist
4drEF's Avatar
TD03U
Old 06-09-2014, 09:56 AM
The plug on the usdm si may be different if not just make sure to disconnect the blue/green and blue/yellow on the usdm si dizzy cuz ur sesnor is located on the exhaust cam outside the dizzy. Otherwise they should be almost identical.
Old 06-09-2014, 09:58 AM
To identify between the 86-89 integra is simple. You want the dizzy from a black valve cover d16a1. Brown valve cover is bad.
Old 06-09-2014, 09:53 PM
JohnED7's Avatar
Alright thanks so much you all. Hopefully I can pick one of these up and this will fix my little issue. Thanks again!
TCHondaMan
01-03-2007 06:55 PM
90hbvtec
05-27-2006 07:28 AM
Ahks
02-11-2006 08:24 AM
SiR_Injected
11-24-2005 11:54 AM
gutted-dx
05-15-2005 04:42 PM
Quick Reply: ZC engine distributor number
