B16A rocker arm adjusting nut comes loose - Honda-Tech
Old 03-23-2006, 10:17 AM   #1
geebs's Avatar
Default B16A rocker arm adjusting nut comes loose
The adjusting nut on the exhaust side for the valve clearance adjusting screw keeps coming loose.. anyone know any remedies? loctite?
geebs is offline   Reply With Quote
Old 03-23-2006, 04:08 PM   #2
tealjdmcrx's Avatar
Default Re: B16A rocker arm adjusting nut comes loose (geebs)
replace the nut and adjuster it very easy. also check the treads on the arm, could be stripped.
tealjdmcrx is offline   Reply With Quote
Old 03-23-2006, 06:37 PM   #3
geebs's Avatar
Default Re: B16A rocker arm adjusting nut comes loose (tealjdmcrx)
ive got a new nut and screw on order.. just curious as to why it would keep coming loose. they were tight, torqued to spec, the screw wasnt stripped. strange.
Old 09-28-2007, 12:03 AM   #4
alaskanlue's Avatar
hey, where u order one from? I got the same problem but it's on my intake side.
alaskanlue is offline   Reply With Quote
loose strut. ZombiePharoh Acura Integra 5 03-06-2012 08:29 PM
Lug nuts coming loose... Byaaah! Acura Integra 7 06-18-2007 08:25 PM
Need to know how to adjust Full Race traction bars crex23 Honda CRX / EF Civic (1988 - 1991) 0 11-10-2006 04:20 PM
B18/B20 rocker arm problem HidPerf Acura Integra 1 02-16-2005 09:10 PM
throttle adjustment.........PLEASE HELP! CrOmEdOmEcHaMbEr Honda Civic / Del Sol (1992 - 2000) 5 02-21-2002 08:00 AM
Tags
accord, adjuster, adjusting, arm, arms, b16, b16a, coming, honda, loctite, loose, nut, nuts, rocker, screw, spec, stuck, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
