B16A OBD0 Knock Sensor Quickie
First off, this is the knock sensor on my OBD0 B16A, correct? It's directly under the intake manifold, close to cylinder #2 I believe.
I had a plug in it, but it was throwing a CEL 23. Here is the plug that was in there while it was throwing the CEL.
It's has orange and black/yellow wires. It fit in the plug whole and matched up wire harness wise so I plugged it in and forgot it. I unplugged it to test if it was a different sensor, because it would throw a new code on top of CEL 23, but it just kept throwing the same code. That's why I'm guessing it's an old plug that isn't used on the new motor. I swapped out a DPFI D15B1 for the JDM B16A. Stayed OBD0. And I guess when I switched the harness over, I was just plugging things in and this wasn't right.
So now I want to know what the plug went to on the OBD0 DPFI D15B1 that was in there before. If it's not important, I'l just going to hack it off and use the plug to run a wire to the ECU for the knock sensor.
Thanks!
Thanks!
Re: B16A OBD0 Knock Sensor Quickie
But that is the knock sensor, right?
Where was this my whole life.
But anyways, I have the green looking sensor on the back. But it doesn't do the fans, or at least I don't think it does. I have the temp sensor on the thermostat housing that does it.
But I will wire the knock sensor and go for gold.
I have a obd0 b16a
when the car get warm check engine light turn on and get code 23
my knock sensor was broke so I replace, wire are good
also I replace the ecu
but I still have the code and vtec don't work
I have a injector lick and my lost motion assembly are bad
idk if the engine are in time
I buy the car with the that engine and previous owner didn't run the engine
T_Rex
02-03-2003 05:09 PM
