A b16 VTEC head on a b20 block.. help?? - Honda-Tech
Old 05-29-2002, 06:14 AM   #1
Default A b16 VTEC head on a b20 block.. help??
Hey guys, I've heard of Frank engines (short for Frankenstien engines) where you swap the heads and blocks of diffent engines in the Honda B series to create your own custom ****.. I just ran by an engine and I wanted to know if it's a good idea.. it's a b16 VTEC head on a b20 block (from a CRV). I wanna drop this into my CRX but I don't know if it's a good idea.. also do ya'll recommend putting a DRAG Gen 3 Turbo kit on it when it's complete.. any info on this swap or the turbo would be great.. thanks in advance
Okay20 is offline   Reply With Quote
Old 05-29-2002, 06:19 AM   #2
FOrSfEd's Avatar
Default Re: A b16 VTEC head on a b20 block.. help?? (LegallyBrown786)
That will be a great idea, I'm also doing this in the coming months, but for more info check out www.crvtec.com . Place for good info on the swap.
Lee
FOrSfEd is offline   Reply With Quote
Old 05-29-2002, 07:08 AM   #3
make sure you build the block and not half *** on it. Those swaps are AWESOME..but it can go bad easily if you don't build it properly
I'm building a b20/vtec for my crx to compete in honda-challenge as well
Jeff-
SpeedMonkeyRacing is offline   Reply With Quote
Old 05-29-2002, 11:56 AM   #4
big pete's Avatar
Default Re: A b16 VTEC head on a b20 block.. help?? (VolcomR)
yah...build it good....you'll regret it if you dont
big pete is offline   Reply With Quote
Old 05-29-2002, 09:06 PM   #5
Default Re: A b16 VTEC head on a b20 block.. help?? (big pete)
Is it just me? or do the links on the CRVTEC.com site not work??
90_Civic_Hatch is offline   Reply With Quote
Old 05-29-2002, 09:57 PM   #6
Default Re: A b16 VTEC head on a b20 block.. help?? (90_Civic_Hatch)
those motors make some good power, but it all depends on how its built. getting it built right will cost you some $$$.
wickedxboi is offline   Reply With Quote
Old 05-29-2002, 11:32 PM   #7
The Boot
Smokinsax's Avatar
Default Re: A b16 VTEC head on a b20 block.. help?? (wickedxboi)
Here's another site that should help. http://www.c-speedracing.com/howto.html (just scroll down a little bit) Also are you going to be building the engine or buying an engine already put together? Build your own or buy from a reputable shop and get it done right the first time. hth
Smokinsax is offline   Reply With Quote
Old 05-30-2002, 12:56 AM   #8
My suggestion... worry about getting the b20 W/OUT vtec into your car. Get it all straightened out & then go w/ a turbo. When you have all that under your belt & settled... then worry about a vtec head.
Going from 112 hp to 330 hp is insane if you have never dealt w/ it before.
Good luck,
Pete
Trickturn is offline   Reply With Quote
Old 05-30-2002, 01:36 AM   #9
REX VT's Avatar
Here you go:
B20z/type R with 11:1 CR pushing 900kg of CRX
Bhp? 230-240 (still running P30)
Torque? Shitloads of them
Fast? No doubt, kills 300bhp E36 M3
[Modified by REX VT, 9:37 AM 5/30/2002]
REX VT is offline   Reply With Quote
Old 05-30-2002, 11:16 AM   #10
Default Re: A b16 VTEC head on a b20 block.. help?? (pest)
what do you mean 112hp to 330?? A b20/b16 head is only 112hp? Are you sure? I'm confused.. someone help please.. I don't know too much bout this swap..
Old 05-30-2002, 12:52 PM   #11
Jeff C's Avatar
here are some b20vtec dynos, along with a bunch of others. keep in mind though that they did not just simply put a vtec head on crv block.
http://www.importreview.com/d_2.0.html
Jeff C is offline   Reply With Quote
3 Stage D15B Block w/D16Z6 Head Timing Issues 89d15crx Honda Civic / Del Sol (1992 - 2000) 24 02-20-2015 08:10 AM
(I Need Advice)Frankenstein Motors B-Series(which combos make the most power ?) ALLmotor_89 All Motor / Naturally Aspirated 26 03-26-2010 02:27 AM
which motor mounts do i use and a b20/vtec engine swap??? af1king1421 Acura Integra 1 07-02-2004 01:05 AM
B21/B20 block with B18C5 head... Ahknodd Honda CRX / EF Civic (1988 - 1991) 7 03-10-2004 08:56 PM
HEELP!!! LS/VTEC engine setup!!!! Root79 All Motor / Naturally Aspirated 6 01-17-2004 08:10 AM
Tags
2000, 98, az, b16, b20, b20b, b20z, block, built, civic, head, hp, integra, sale, si, tubro, vtec, week
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
