B16 battery light advice - Honda-Tech
Old 11-07-2009, 01:06 PM   #1
I like the tuna here
DumpdEJ6's Avatar
Default B16 battery light advice
I've got a JDM b16 in a 1990 hatch. I just recently had an accident where I hit the back of this girls car at around 5-10mph. It bent up the headlights, rad support, bumper filler, and the hood, but I bent most of that back into place. Whats going on now is the battery light started flickering off and on, mostly on, after the accident. This went on for two weeks, I thought my battery just got jostled around or something, so I tightened up everything I could see that I thought might be the problem. Still flickering, but it didn't seem to be effecting anything so I put up with it for a while.
Fast forward to last night, I was driving along and the radio started cutting off, then coming back on for a second, then cutting back off and finally staying off. Then I noticed the dash clock getting really dim, then the car started running poorly, not wanting to rev at all. Then my turn signals stopped working and the head and taillights began to dim to almost nothing. I was able to limp it home where it sits right now. My question is: what is most likely the culprit here? Obviously my battery ran out, which leads me to suspect that my alternator stopped working. Am I missing something else it could be? Nothing contacted the motor when I hit the other car, so I assumed it was ok...apparently I assumed wrongly, lol, but I didn't think a little shock would mess up my alternator...
Any ideas as to what this might be?
DumpdEJ6 is offline   Reply With Quote
Old 11-07-2009, 06:12 PM   #2
DumpdEJ6's Avatar
Default Re: B16 battery light advice
bump for help...I'll be taking the alternator out tomorrow and getting it tested, but is there anything else it might be? I still don't think the bump the car sustained would ruin the alternator...
Old 11-08-2009, 08:43 AM   #3
gringo7718's Avatar
They are probably not related and just a coincidence.
Check that the battery connections are good, and check your engine ground cables. Make sure the alternator belt isnt slipping and that the alternator plug is connected correctly.
gringo7718 is offline   Reply With Quote
Old 11-08-2009, 01:57 PM   #4
DPSJosh's Avatar
Sounds like a bad alternator/battery to me. Most likely the alternator. Take it up to AutoZone or something and have them test it.
Like posted above, probably just coincidence.
DPSJosh is offline   Reply With Quote
Old 11-08-2009, 02:01 PM   #5
tico's Avatar
Make sure none of the wires got punched causing excessive curent draw which can kill an alternator. If its all good. It might be bad timing for both.
tico is offline   Reply With Quote
Old 11-08-2009, 06:09 PM   #6
DumpdEJ6's Avatar
Nail on the head. I took it up to Autozone and they found that BOTH the battery and alternator were bad. :-(
Oh well, I needed another battery anyway, the behemoth sitting in the engine bay now is so big it is resting on my clutch cable lol.
Old 11-08-2009, 06:10 PM   #7
DumpdEJ6's Avatar
Quote:
I'll check that for sure. It seemed like a hell of a coincidence...
Old 11-08-2009, 08:45 PM   #8
97 ek coupe's Avatar
sounds like the alternator
97 ek coupe is offline   Reply With Quote
Alternator VS Fuel Pump Relay greenmachin93LX Honda Accord (1990 - 2002) 13 08-04-2014 12:51 PM
car stalled & got jumpstarted, then i had no headlights, signals, gauge lights ? crxaddikt Honda CRX / EF Civic (1988 - 1991) 11 10-05-2012 12:58 AM
Battery Light Flickering (I searched) bobjohnson Honda CRX / EF Civic (1988 - 1991) 8 08-08-2007 01:15 PM
Car died, no power in system, no battery light, not the alternator... (searched) HELP stRodda Honda Accord (1990 - 2002) 5 10-02-2005 11:20 PM
Help! Battery light comes on under hard acceleration p1driftfiend Honda CRX / EF Civic (1988 - 1991) 6 01-08-2005 12:28 AM
Tags
91, alternator, b16, b16a, battery, check, coming, ef, flickering, good, honda, hondatech, light, on, prelude
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
