D15B2 Head gasket placement???
Hey all
I've been lurking for a while and I've learned a bunch... Thanks.
But with all the modding going on I can't seem to find the info I need to finish a SOHC head install. I don't need much but when I put it together I got a few oil leaks I shouldn't have.
I've figured most of them out but one in particular is bugging me cause I can't find any info on it, the spark plug tubes on the camshaft holder.
I bought rebuilt head off ebay and when I pulled the existing head from my car I saw that there weren't any gaskets under the holder. I've read that some d15b s didn't have rubber gaskets but when I used the high temp silicone gasket it failed and the spark plug tubes leaked bad.
So searching like a mad dog I can't find any guides for the head gasket kits.... and the Haynes book sucks. I'd get a factory service manual but I'm giving the car to a friend and I'd like to give him a solid good running car and not a leaky pos.
Any one have the head gasket guide available to upload?
Thanks....
You guys rock, keep up the good work.
Thanks....
EFB055
Re: D15B2 Head gasket placement???
Are you talking about the O ring that sits around the hole you put the spark plug in? That sits under the valve cover?
They're quick and easy to replace.
No, not the valve cover O-rings.... The main gaskets I want to see are under the camshaft holder, I believe they are the rubber O-rings shaped like an '8'.
But I have the full top end gasket kit and although most gaskets are doubles cause of the rebuilt head, there are others I want to confirm I ain't missing on the re-reassembly.
Most are obvious, I just want to make sure this is the last time I have to go under the hood for a while. I'm heading to the car right now so I'll just have to work it out on my own, but I case I miss something I could still use the gasket placement guide..... Anyone?
I know what you're talking about. They're under the rocker arm assembly. I bought a gasket kit ($30) off ebay, it's been running fine no problems. But that kit came with everything I needed.
Well I had a full top end gasket kit and since the head was rebuilt by some else, changed all the gaskets, 0-rings and seals outside the head I could find matches in the kit.... There are a lot of gaskets and O-rings left, I sure hope I didn't miss any more important ones. My marks kinda rubbed off and I think I set the timing belt off a tooth, so I'll have to reset the timing to TDC and the cam to #1ic.
I'd still like to see a diagram of the top end gaskets if anyone knows where I can DL one.... I would and do appreciate it... Thanks
