Axle problems
Axle problems
For a while when I make hard lefts I notice a clunking noise which i suspect is the inner CV joint on the drivers side axle. Upon inspection I noticed the inner boot is shot and the axle has some front/back play in it.
Should I replace the inner CV joint and boot or just get a new axle altogether? On Honda's is it okay to replace just one axle? Passenger axle seems to be fine. BTW, I have a Integra JDM B16A with J1 tranny so I assume I have the integra intermediate shaft which means I need 90-93 integra axles correct? Any recommendations on where to get a single axle? (Autozone/Kragen) Thanks guys.
1 Post
just replace both axles (recommended if you got the doh) check autozone or pepboys...
i got mine from the j-yard... so you might as well want to check over there too
Re: (92integra_gs)
Just checked 3 places and Autozone had it for the cheapest at $69.99 + refundable core w/lifetime warranty. At that price I'm just going to replace the entire axle.
Re: Axle problems (Reelizmpro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reelizmpro »</TD></TR><TR><TD CLASS="quote">90-93 integra axles correct? </TD></TR></TABLE>
Yep and ask for non abs axles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs »</TD></TR><TR><TD CLASS="quote">just replace both axles (recommended if you got the doh) </TD></TR></TABLE>
Pwnmeister
06-25-2013 07:55 AM
