axle problem? - Honda-Tech
axle problem?
Old 08-12-2009, 04:39 PM   #1
Track Advocate
BLU CIVIC's Avatar
Default axle problem?
started while driving to work on monday. sitting at a light and it turns green an i get vibration from the drivers side like there were indentions in the road. didn't think nothing of it. i drive about another 10 miles and at another light. light turns green and the vibration is more noticeable and pulls a little to the left. don't think anything of it b/c i still think it's the road. i hear a metal noise and dismiss that as the car going past. few miles later at another light. well i take off from the light and vibration has grown increasingly noticeable and the metal noise is very audible. i'm thinking my wheel is going to fall off or something. i get to work and jack up the car. i spin the wheel w/ no sound coming from it and no play from the wheel bearing. later that when when my wife comes to pick me up she drives it around the parking deck and no sound at all coming from it. could it very well be my axle? the inner boot has been torn for over a year now. i'm getting new axles either way, but i want to know if the problem could be related to something else.
BLU CIVIC is offline   Reply With Quote
Old 08-12-2009, 05:56 PM   #2
DO IT ON ALL FOURS
OneBadTurboCRV's Avatar
Default Re: axle problem?
Axle or Wheel Bearing would be my bet.
OneBadTurboCRV is offline   Reply With Quote
Old 08-14-2009, 06:00 PM   #3
Track Advocate
BLU CIVIC's Avatar
alright, changed my axles...problem i described went away, but there's something new
drove the car around after changing the axles and everything seemed fine. but on the way home i got some vibration whenever i pressed the gas hard. also got vibration after taking a turn...so, any help
Old 08-14-2009, 07:30 PM   #4
monster_ls/vtec's Avatar
tire out of ballance...or still wheel barring
monster_ls/vtec is offline   Reply With Quote
Old 08-14-2009, 07:42 PM   #5
Track Advocate
BLU CIVIC's Avatar
before there was a lot of vibration from a stop, but none of that, no pulling to the left or metal noise...checked the bearings and it's solid with no play...but i'm going to go over the car again in the am
Old 08-14-2009, 08:36 PM   #6
ef nine's Avatar
maybe it still the axels , cause i got the same problem like you before and the guy change my axel(pass' side) went to pick up and there's still vibration when i took off. took the car back ask him to check it again, and he end up change other axel.after the 2nd axel my car was ok no more vibration!!!
ef nine is offline   Reply With Quote
Old 08-14-2009, 08:41 PM   #7
Track Advocate
BLU CIVIC's Avatar
did you get another new axle? i've read about people having problems with new axles and having to replace them
Old 08-14-2009, 08:59 PM   #8
ef nine's Avatar
no, i got rebuild one, you know the way the shop do, they will order you new one (used but rebuild) then when they got it they took my messd up one out and replace with the rebuild one. then my car still got the vibration. took it back he take a look at the axel and told me that he gonna change to other one, got new one no more problem.......i mean all of the axel are all re build unless you want to buy like a new new one which it will coast you more!
Old 08-14-2009, 10:30 PM   #9
does it clunk when you make any turns?
dseriesdemon is offline   Reply With Quote
Old 08-15-2009, 06:15 AM   #10
Track Advocate
BLU CIVIC's Avatar
no clunking when i'm turning, just vibration when i hit the gas coming out of it
Old 08-15-2009, 04:20 PM   #11
Get the tranny inspected. I'll bet the crappy old driveaxles you had wore down the splines in the tranny. Weird thought, but I've heard of crazier. Might wanna just consider a whole tranny swap 2. if the clutch is still good, you can go to a ricer shop and pick up an si tranny for less than 300 and it'll be under warranty... Then check your new driveaxles while you have them pulled, and make sure the splines aren't messed up..
P.S. Don't forget that some tranny's are hydraulic, and others are cable... I almost had that happen to me, but i caught it before purchase.
Old 08-20-2009, 07:24 AM   #12
Track Advocate
BLU CIVIC's Avatar
i think i pinpointed the problem, or know where it's coming from...maybey you can hear it over the sound of my valves i think it's the axle...wasn't any problems until i put new axles on
Old 08-20-2009, 07:54 AM   #13
Sounds like a wheel bearing.
ernesttex111 is offline   Reply With Quote
Old 08-20-2009, 02:34 PM   #14
check the brake dust plate and maby wheel bearing
Old 08-20-2009, 07:13 PM   #15
When I noticed that same noise on my 90 Hatch it turned out to be that the axel itself was slightly bent. Which caused the vibration.
90civicstdgold is offline   Reply With Quote
Old 08-21-2009, 04:29 AM   #16
Track Advocate
BLU CIVIC's Avatar
Quote:
i'm replacing one side at a time this weekend
Old 08-24-2009, 08:15 AM   #17
Track Advocate
BLU CIVIC's Avatar
well changed the drivers side and the vibration was still there and started on the passenger side, but found a problem...can't get the axle out of the spindle. looks like the threads may have crossed...i've been hammering and using a pry bar since yesterday
Old 08-24-2009, 09:11 AM   #18
DO IT ON ALL FOURS
Sounds like the axle was not compressing the wheel bearing all the way because of the cross threaded nut not allowing full torque which in turn led to bearing failure.
Old 08-25-2009, 08:07 AM   #19
SETI20's Avatar
Sounds like an inner CV joint issue to me.
SETI20 is offline   Reply With Quote
Old 08-26-2009, 06:11 PM   #20
Track Advocate
BLU CIVIC's Avatar
anyone know which spindle/knuckle will work other than an Si
Old 08-28-2009, 01:51 AM   #21
there is something very wrong with your lights.check it as soon as possible otherwise you will have to face much more problem than you have expected to have.
jenifertom90 is offline   Reply With Quote
Old 08-29-2009, 11:45 AM   #22
Track Advocate
BLU CIVIC's Avatar
axles replaced, tires balanced...problem still there...wheel bearings next, after that...
2000 civic dx coupe vibration Julian Mendoza Honda Civic / Del Sol (1992 - 2000) 5 07-25-2016 10:50 AM
92 integra noise up front under acceleration dadrought6 Acura Integra 8 01-09-2012 07:23 PM
Axles tamadrummer1120 Honda Accord (1990 - 2002) 6 10-13-2009 08:48 AM
Troubleshooting noise/vibration...bad bearing or axle? Schmitey Honda Accord (1990 - 2002) 10 06-23-2008 10:46 PM
Could someone PLEASE help me pin down this steering/drive shaft noise? travis Acura Integra Type-R 3 01-08-2002 08:24 AM
Tags
2000, accord, acura, axel, axle, axles, back, car, changing, civic, hard, honda, problem, problems, sound, tl, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
