autozone alternator bench test PHONY! - Honda-Tech
Closed Thread
Old 07-12-2011, 05:30 PM   #1
Default autozone alternator bench test PHONY!
I MADE THIS THREAD TO LET EVERYONE KNO THAT I BOUGHT A ALTERNATOR FROM AUTOZONE INSTALLED IT BATTERY LIGHT CAME ON TOOK IT OFF BENCH TESTED IT THEY SAID IT WAS GOOD INSTALLED IT AGAIN SAME PROBLEM CHECKED ALL MY FUSE, FUSIBLE LINKS, WIRING ALL THE WAY TO THE ECU PUT THE MOLTIMETER TO IT ETC. I WENT BACK SAID JUST GIVE ME ANOTHER ONE AND I INSTALLED IT AND WORKED FINE SO DONT ALWAYS BELIVE THAT BENCH TEST
nikez4me is offline
Old 07-12-2011, 05:48 PM   #2
CRX Toad's Avatar
Default Re: autozone alternator bench test PHONY!
This has nothing to do with this forum.
CRX Toad is offline
Closed Thread
91 battery light on below 2500RPM dazebreak Acura Integra 3 08-15-2015 06:53 PM
Battery not charging on 92 civic after second alternator! What could it be? willpower102 Honda Civic / Del Sol (1992 - 2000) 5 07-28-2013 06:12 PM
No crank.. bennyDA Tech / Misc 0 03-03-2008 03:13 PM
Is bench bleeding necessary if i will later bleed all 4 brakes? dng Tech / Misc 1 04-18-2004 10:55 PM
How to test an alternator when its out of the car ? RCautoworks.com Tech / Misc 4 01-15-2003 08:13 PM
Tags
2000, allterner, alternator, auto, autozone, bench, check, civic, ef, good, honda, hondatech, test, testing, zones
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
