gsr wont idle
Old 11-12-2011, 06:44 PM
civicef990's Avatar
Icon2 gsr wont idle
soo im getting my car ready for paint n i havent start the engine for about a week...but before that i took my stock tb off to test fit a 68mm tb...when i put the 68mm tb on the car would only stay on if i hold the gas open just a bit plus the check engine light came on....code 7 for tps at the time i didnt feel like putting my stock tb back soo like i said the car sat for about a week...now i put my stock tb on and the car does the same thing it wont idle if i dont hold the gas...there is no code 7 i got a code 22 VTEC pressure valve that shouldent make my engine do that would it?
any ideas??
engine is a supercharged gsr in a civic hatch
thanks to everyone in advance
Old 11-12-2011, 06:49 PM
91efbluehatch's Avatar
Default Re: gsr wont idle
check your Fast Idle Thermal Valve, FITV, and your IACV.
clean em out really good and see that that does.
take your TPS and swap it with one that works, and see if that helps.
you might have to calibrate it as well
Old 11-13-2011, 02:14 PM
civicef990's Avatar
i dont have a fitv i have a 99 SI tb on my car n with my SI tb i dont get a code 7 but i still have a code 22
i will try cleaning mu iacv tho
thanks
Old 11-15-2011, 03:15 PM
civicef990's Avatar
bump
Old 11-15-2011, 03:23 PM
how you gonna bump it whenever you havent even gotten back with us for an update?
Old 11-15-2011, 05:32 PM
civicef990's Avatar
oh **** my bad i thot i typed it in
but took off the iacv and cleaned it looked fine when i took it off but i still cleaned it...and im still having the same ploblem
i know the tb is good because i put it on my friends car and it works just fine
thanks for you reply
Old 11-16-2011, 02:53 PM
civicef990's Avatar
soo today i tryed 3 good working iacv outta my friends cars and is not changing anything so im guessing mine is good too....i cleand the tb still nothing....the problem is only happening on cold start after that the car idles just perfect at about 900rpms
need some help idk what to do there is no check engine light nothing
thanks everyone for replys
Old 11-16-2011, 03:16 PM
Keyboard Humorist
4drEF's Avatar
Cold start only... interesting.
Any hiccups when you are driving?
What ECU are you running? Chipped?
Old 11-17-2011, 11:50 AM
civicef990's Avatar
yeah only cold start...n no hiccups car revs fine drives fine goes into boost just fine too, it will redline with no problems
gsr on supercharger on a chipped p72 and is tuned....ones is hot the car will idle perfectly at 900rpms after is warmed up
Old 11-18-2011, 02:13 PM
civicef990's Avatar
bump!!
Old 11-20-2011, 08:14 AM
civicef990's Avatar
bumppppp
Old 03-13-2012, 07:48 PM
bigpunn421's Avatar
did you ever fix this issue?
i am having warm idle problems with my jrsc gsr. i dont know what it could be
Old 09-26-2012, 08:52 PM
end005's Avatar
Any updates or help with this same issue?
After i got my blower ported i started having this issue. On cold days, my car had a real hard time starting up and idling unless i have my foot on the gas. Once the car is warmed up, the car idles perfect, drives perfect, and have no issues. The car even starts perfectly on cold starts when its hot.and humid out. Its only a cold start on a cold day.
Now, my car wont even start up. Please help.
Old 01-15-2023, 07:52 PM
massimo.ek's Avatar
Hey guys, I know this thread is old. I have a b18c gsr in an ek, i cant get it to idle for the life of me, At first I never even had the iacv plugged in so i thought that was my issue, i wired it up and it still wont idle, the car will turn over for a second but dies when if i dont give it gas, i hear a squeak coming from the tb. I havent tried to clean out the tb or iacv. Ill give that a try, could it be my throttle cable as well? how much slack should it have? Any help would be great. This is my first swap and its really discouraging that i cant get it to idle and hear my car. Thanks guys
frostykue
03-28-2013 08:29 PM
babohyungjin
09-19-2010 07:43 PM
poppypizza
05-01-2008 07:47 PM
I CRX I
09-27-2007 10:39 AM
revhardsi
02-22-2006 03:03 PM
Quick Reply: gsr wont idle
