atmospheric pressure sensor?
where is the atmospheric pressure sensor located on an obd1 gsr motor? I searched and found how to test it but not where it is at
Re: atmospheric pressure sensor? (GsrTurboCRX88)
the motor/ecu is usdm? if so, the "atmospheric pressure sensor" is located inside the ecu....if its jdm then i have no clue and i dont even think they have them anyway..
but yeah to fix it you need to get another ecu or chip the ecu you have and disable that thing
Re: atmospheric pressure sensor? (88DXCRX)
^^ thats on obd0 cars only..if he's throwing that code with the obd1 ecu,,then its reffering the sensor in the ecu itself,,because the obd1 computer knows nothing of the sensor on the firewall..
1 Post
Re: atmospheric pressure sensor? (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">^^ thats on obd0 cars only..if he's throwing that code with the obd1 ecu,,then its reffering the sensor in the ecu itself,,because the obd1 computer knows nothing of the sensor on the firewall..</TD></TR></TABLE>
atmospheric, automobiles, b18, barometric, check, civic, crx, ecu, ef, fix, honda, obd1, pressure, replacement, sensor, sensors, trucks
