Which asr subframe brace do I use for an ef
Old 05-19-2009, 12:57 PM
acmoc's Avatar
Default Which asr subframe brace do I use for an ef
Hi, I noticed some people are using an asr rear subframe brace from a newer civic on the old ef's. Just using the two main holes. Can someone tell me which one it is?
Thanks
Old 05-19-2009, 01:08 PM
rex714's Avatar
Default Re: Which asr subframe brace do I use for an ef
maybe the eg one
they use the eg rear lower tie bar on it
Old 05-19-2009, 01:20 PM
gringo7718's Avatar
There is absolutely no function for this brace on an EF. It is used on other civics because they have rear sway bars that attach to their rear subframe. The EF sway bars attach to the frame rail and do not attach to the rear subframe. You would be better off with an ebay rear stabilizer bar.
Old 05-19-2009, 01:43 PM
egyolk's Avatar
can someone confirm/second this as I was asking the OP's quetion myself?
TIA
Old 05-19-2009, 01:59 PM
gringo7718's Avatar
The rear sway attaches to the rear frame rail in an EF. It does not attach to the rear subframe, so there is little need to reinforce this part.
Here is a pic of someone who attached a subframe reinforcement from another car. In this application, the part is purely for looks and serves no functional purpose.
Subframe reinforcements are needed only for cars that have strong rear sway bars that actually attach to the rear subframe and place stress on them. In those cars it is important to reinforce the subframe to prevent tearout. (For EFs it is a useless part.)
Old 05-19-2009, 04:15 PM
mr3sgte's Avatar
I could be mistaken, but I believe the bar from Progress connects to the rear subframe instead of the tow hook mounts.
Old 05-19-2009, 05:54 PM
tallkan's Avatar
yea im runnin the progress sway bar on my crx it connects to the subframe its held in by the bolt that goes to the lower controll arm. then u weld the bracket to the subframe. theres really kno way to run the asr brace wit the progress sway bar. lemme kno i u guys want pics of the progress bar on a crx
Old 05-19-2009, 07:05 PM
garageEF's Avatar
Do it!!
Anybody know if you can run a EG sway on an EF using the ASR brace?
Old 05-19-2009, 07:59 PM
gringo7718's Avatar
Progress seems to have the worst design of all the rear sway bars for the EF. They use nutserts which break over time and so people just weld them to the subframe. Only problem is that the subframe was not designed to be stressed in this manner and the welds eventually fail. On top of having the worst design they are also the most expensive ($250)
If you are in the market for a rear sway bar many people are happy with the Suspension Techniques, Tanabe, and ASR Bars.
Here is a link to Progress website with a PDF of the installation manual.
http://www.progressauto.com/products.../productID/574
Here are some pics of the welds failing and a link about it.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/what-rear-sway-bar-you-running-2430343/
Old 05-20-2009, 12:42 AM
tallkan's Avatar
If you are in the market for a rear sway bar many people are happy with the Suspension Techniques and Tanabe Bars.
https://honda-tech.com/forums/showthread.php?t=2430343
i havnt seen any body else wit that prob. i hope that **** dosnt crack. mayb your chassis was allready weak from all the rust. thanx for the pix ill post some of mine up 2morrow
Old 05-20-2009, 12:43 AM
NlCK B's Avatar
ASR will be coming out with a kit for the ef this summer just be patient the kit will be similar to the current da kit
http://www.weaksauceparts.com/store/...9&cat=0&page=1
this is the conversation i had with ASR
NlCK BERMUDEZ (2:52:14 PM): is there any way to get a 24mm kit for the ef maybe using the 32mm hardware with a da 24MM BAR?
NlCK BERMUDEZ (2:53:15 PM): EF=88-91 HONDA CIVIC
ASRTECH (3:41:31 PM): Hello Nick, we will be working on an EF kit similar to the DA that we offer now.
ASRTECH (3:42:09 PM): it should be out early summer
NlCK BERMUDEZ (3:42:44 PM): thanks allot is there going to be a waiting list
ASRTECH (3:43:18 PM): no there wont be any waiting list there should we will make plenty of them for every dealer
NlCK BERMUDEZ (3:45:50 PM): thanks again i'll definatly be buying one of these
ASRTECH (3:46:45 PM): thank you for your interest! it will be very similar to the DA kits as seen on G2IC.com
Old 05-20-2009, 07:23 AM
gringo7718's Avatar
This is Blaak-crx's car and he did say that the cracks happened after 4 years of track duty. Even so, it is still the worst design on the market and if it was designed properly, he would never have had to weld it in the first place.
ASR does have a rear sway bar kit that mounts to the tow hook location. The kit is structurally sound and offers the biggest bar, but it seems like this kit interferes with most exhausts.
Old 05-20-2009, 10:27 AM
tallkan's Avatar
Originally Posted by garageEF
Do it!!
Allright guys got pics off my progress sway bar on my crx. my camera phones kinda shitty
IMG]http://i228.photobucket.com/albums/ee289/Tallkan1979/Photo_052009_002.jpg[/IMG]
Old 05-20-2009, 01:28 PM
acmoc's Avatar
Originally Posted by rex714
maybe the eg one
ehh umm eg? 92-95 civic hatch?
Old 08-03-2009, 10:25 PM
Nickstadx's Avatar
http://cgi.ebay.com/ebaymotors/ASR-S...Q5fAccessories
here they have one listed for the ef is this right ? and a sway bar that fits to the brace ???
Old 08-03-2009, 11:44 PM
specialized108's Avatar
is there any other benefit for the rear lower tie bars? increased handling,stiffness or anything that would remotely make a difference? to the cars performance?
don't mean to thread jack, just wondering if it would help reinforce anything if you were running a different rear sway that it was not needed on (im running a st sway)
Old 08-04-2009, 10:40 AM
bryse68's Avatar
JHPUSA HAS THE EF ASR BRACE
Old 08-04-2009, 01:31 PM
vtechjunkie's Avatar
So just a straight bar that attaches to both holes is all you need. I can make that easy!
Old 03-05-2011, 05:54 PM
Ef2 Oh sickness's Avatar
Default Witch Subframe do i use on ef?
This is on my car Blox Lca Asr Subframe Sway Bar and beaks bar
Old 03-06-2011, 04:23 AM
CRX Toad's Avatar
This is a 2 YEAR old thread.
Old 03-14-2011, 07:19 AM
88CReXin's Avatar
This is true, but I'm glad I looked at it because I was about to order the Function 7 subframe brace for a 92-95 Civic and put it on there. At least I can see some of the problems I will have
Old 03-14-2011, 08:57 AM
macef9's Avatar
Old 07-22-2015, 08:42 AM
Player_One's Avatar
Wow, I'm reviving an ancient thread. I'm posting to correct some misinformation. The ASR (and similar) subframe braces are to prevent tear out at the control arm mounting point. The spots for the sway bar brackets is just secondary.
Here's what a tear-out looks like. Google Civic subframe tear for more info.
Alternate options to subframe brace? - D-series.org
Old 07-22-2015, 10:00 AM
Keyboard Humorist
4drEF's Avatar
Stay in school.
As already mentioned in this ancient post, that type of tear out does not occur on the EF chassis because EF sway bar mounts to the frame rails and NOT the subframe.
That link shows picks of newer chassis where a heavier sway bar was used and mounted to the subframe (non-EF chassis).
Old 07-22-2015, 10:13 AM
CRX God
whited's Avatar
^Wrong
Originally Posted by 4drEF
Stay in school.
^Correct
EF's entire sub-frame can tear out or bend. Mine kinked.
mikeSMASHES
03-09-2013 04:57 PM
Pre_4_Me
11-21-2008 04:02 PM
gringo7718
23
06-08-2008 06:43 AM
Quick Reply: Which asr subframe brace do I use for an ef
