anyone got a dash wiring diagram for a EF?
Re: anyone got a dash wiring diagram for a EF?
Are you blind, lazy, or both? check the threads that have RECENTLY been active and there is THIS ONE...
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/anyone-got-dash-wiring-diagram-2496674/
nimrod...
nimrod...
Okay thank you for the useless info, I asked for the dash color code or diagram meaning the full harness not a specific part of the harness. now can anyone not rude and someone who is a lil smarter tell me where to find the FULL dash wiring or color code...there is 6 wires cut where the stereo is that is not being used so i would like to know where or what they go to or if they aren't even needed...
Keyboard Humorist
Best bet would be to invest in a service manual... not the Chilton/Haynes junk either.
Helms/Honda one is what you want.
It's something like $60 and will serve you the entire time you own your car.
you can find illegal PDFs of it on the internet, but that's on you.
Anyway, the six wires that are cut.
Do you have a radio? Does everything work in your car?
It makes it a lot easier to look for in the wiring diagram (pages and pages long) if you can provide a little more detail.
there isn't a separate wiring diagram with colors for the complete dash harness - the wiring diagrams are broken down to separate diagrams for the circuit served, i.e. stereo system, gauge cluster, cigarette lighter, heater/AC air delivery, integrated control unit, etc.
Okay everything work's except the dash light's.there is no lighter so don't know if it used to work, i let someone install a stereo in and the dash light's wouldn't work after that... i unhooked the stereo and still no dash light's, so i reinstalled the stereo and have the 6 wire's left that someone had cut before i owned the car, although the dash light's worked then but not since i let the people do the stereo. there was a blown fuse but have replaced it and rechecked the fuses under the dash again and even under the hood. but looking at the fuse box there's a lot of fuses not in certain places so i am not sure if even all the fuses are in their proper places..
im here to tell you they dont know.i had a problem with the wiring in my 88 ef and had to go it alone,because the excuse is search for your self ,although they look at the post and have the same model.my best answer is get another underdash harness, car-parts.com should have one somewhere.
dont do car-parts.com, not to be mean but you can fit it in your tool bag from the junk yard. I got to the JY about 3 times a week, never pay for a dime of wire from there cause they dont charge for wire.
Did you check and see if the fuse blew out for your interior, and exterior lights? i bet that the little phuckers that put in your stereo tapped into a waire they shouldnt have and grounded it out or something along those lines, so check the fuse and see form there.
Okay i found 1 fuse blown and replaced it, but there is a lot of empty spaces in the fuse box under the dash so I am not sure because i have no idea if that is all that's to be there... but every fuse there i have checked are all still good as of today. I do not have panel for the fuse box to know what goes where or even to know if i am missing any.
Just out of curiosity. Is your new stereo setup with new wires or they are using preexisting wiring. Mine 88 STD is prewired for rear speakers and it obviously did not have those so they just hang there, by the stereo unit.
the first pics is all the wires that were cut where the stereo goes, but the harness had like tree limbs (certain wires wrapped in tape) 3 way like that... and the other pics is what i was saying about maybe just not having all the fuses in the box... and the last pic is what wires are left after i installed the stereo back in using the color codes found online
hondacivickid
07-13-2013 06:54 AM
gummiegorilla
07-30-2009 07:32 PM
smokincrxwannabe
02-08-2008 04:25 PM
