AC.....Vents a smoking?
Old 05-29-2003, 02:06 PM
PoonHunter's Avatar
Default AC.....Vents a smoking?
The other day I was drivin on the freeway and decided to use my A/C. I had the controls on #2 for fan speed...had the fresh air vent selected to allow fresh air and the temp turned all the way to the blue. Any ways I noticed a lil bit of white steam/smoke coming from the center vents. It would just puff it for a second or so. It went away and cameback like twice. Could this be cause the a/c is almost never used in like a year or so? I didnt really notice it since but then again I didnt use it today.
Old 05-29-2003, 02:09 PM
DJ_SaNdOz's Avatar
Default Re: AC.....Vents a smoking? (PoonHunter)
are you sure that it was smoke?
Old 05-29-2003, 02:28 PM
RCautoworks's Avatar
Same thing happen to me once, it was the first hot day and I turned it on and it did it. Nothing bad ever happen to it, so I would not worry about it.
Old 05-29-2003, 02:45 PM
jdircksen's Avatar
It's condensation, not smoke. Don't worry about it.
Old 05-29-2003, 03:34 PM
JCRacer18's Avatar
put your climate control to recirculate the air and the "smoke" should clear
Old 05-29-2003, 03:52 PM
ElementMotor's Avatar
that happened to me once too and i didnt know WTF it was......nothing ever happened so i ignored it......
Old 05-29-2003, 03:57 PM
slywfbpsi's Avatar
Default Re: AC.....Vents a smoking? (EF8 ownz u)
it happened to me earlier this year, but it was alot of smoke, I had blew a a/c line, the bracket had come loose and the line was resting against the exhaust manifold when I hit the button.
Old 05-29-2003, 07:44 PM
scn095's Avatar
It's probably condensation, but slyfbpsi could also be right. A friend's AC system had gone bad and his would "smoke" immediately after he turned it on, too.
Was it making the air as cold as you expected? Did you notice any unusual smell (besides musty) when the "smoke" was coming out of the vents?
Old 05-29-2003, 07:59 PM
drjondurst's Avatar
When I first got my CRX, on the way home it did this.. I was like 'WTF... we're takin this **** back!'
It was cool tho, nothing ever happend. It still does it till this day..
Old 05-29-2003, 08:44 PM
PoonHunter's Avatar
Default Re: AC.....Vents a smoking? (scn095)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scn095 &raquo;</TD></TR><TR><TD CLASS="quote">It's probably condensation, but slyfbpsi could also be right. A friend's AC system had gone bad and his would "smoke" immediately after he turned it on, too.
Was it making the air as cold as you expected? Did you notice any unusual smell (besides musty) when the "smoke" was coming out of the vents?</TD></TR></TABLE>
No wierd smell. It seem cold and eventualy went away. It literaly smoked for like 1 to 3 seconds max but did it twice and hasnt since. Im just curious if it was just because i dont use it much
Old 05-29-2003, 10:01 PM
Vinceg99's Avatar
Had that happen on a BMW that my brother in-law owns he just had the A/C recharged and did it as soon as he turned it on it was almost like it was that cold or something. I wouldnt worry about it unless it has a sweet smell to it or something.
Old 06-03-2003, 08:48 PM
StorminMatt's Avatar
Default Re: AC.....Vents a smoking? (Vinceg99)
Condensation from the vents is usually a sign of a bad A/C thermoswitch. In other words, it is not cycling the compressor off. But this is not something that requires immediate attention.
Old 06-04-2003, 05:00 PM
PoonHunter's Avatar
Default Re: AC.....Vents a smoking? (StorminMatt)
Does this mean my ac is still running when the switch is off?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">Condensation from the vents is usually a sign of a bad A/C thermoswitch. In other words, it is not cycling the compressor off. But this is not something that requires immediate attention.</TD></TR></TABLE>
Old 06-05-2003, 05:19 PM
No. It means the switch is not turning off and the evaporator is getting too cold.
dtran002
11-27-2013 08:57 AM
em1effekt
11
01-04-2011 06:41 PM
pr0gress
08-16-2005 12:21 PM
1hotcivicSi
04-24-2004 06:40 AM
Z6REX-SI
12-30-2003 09:00 AM
Quick Reply: AC.....Vents a smoking?
