AC/heater control Lights Out!!!
Old 11-18-2005, 07:22 PM
tapuout's Avatar
Default AC/heater control Lights Out!!!
Does anyone know a quick fix or ??? my 90si rex's ac controller lights are all out. The buttons all work and I can hear the movement from vent to vent...any ideas guys?
Thanks!
Old 11-19-2005, 09:22 AM
sam385's Avatar
Default Re: AC/heater control Lights Out!!! (graciebjj)
are the bulbs burned out?
check the connectors and wires. since this is near the stereo, someone could have caused an open circuit to the lights while they were installing/servicing the stereo....
Old 11-22-2005, 07:17 PM
tapuout's Avatar
Default Re: AC/heater control Lights Out!!! (sam385)
If it is the bulbs how do I change them...i'm not mechanically inclined.....I'd have to have step by step instructions. If you can help i'd appreciate it. Thanks!
Old 11-28-2005, 11:33 PM
tapuout's Avatar
The lights that dont' work on the heater/ac control are the little pictures of which vent is on....They don't light up. How do i fix them....is it an individual bulb for each button or i'm guessing it's one whole bulb. Please help. Thanks!
Old 11-29-2005, 05:17 AM
b18_crx's Avatar
bump i have same problem.................. the actual indicators work fine(the ones that light up when you switch from floor to defrost and all that) but when i turn on my lights on the thing wont light up............... does the climate control have bulbs just like the cluster or similar
i need to change em its startind to bug me
Old 11-29-2005, 07:20 AM
strictlyimport's Avatar
Default Re: AC/heater control Lights Out!!! (b18_crx)
bump.......I have the same problem with mine. Just the buttons that switch the air movement, everything else lights up....someone please get us the answer....How do change the bulb(s)?
Old 05-07-2006, 10:50 AM
Turbo Dan's Avatar
bump, i have this problem too
need to know what wire/fuse controls them
could it be because my dimmer is not connected?
Old 05-07-2006, 11:18 AM
NastyHabitzCRX's Avatar
Default Re: AC/heater control Lights Out!!! (Turbo Dan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Dan &raquo;</TD></TR><TR><TD CLASS="quote">
could it be because my dimmer is not connected?</TD></TR></TABLE>yup the dimmer switch on the instrument cluster is what provides them power. is you dash lights out too?
Old 05-07-2006, 02:03 PM
marquisdee1018's Avatar
It's good to know that I'm not the only one that has this problem. I'm pretty sure that my bulbs are out. I hate to take my a/c control out and break it again.
Old 05-07-2006, 03:18 PM
bullet647's Avatar
gotta take off console and remove your radio, there are four screws holding the ac control unit in..three in front and one under,then slide unit down, there are four clips holding in face panel just pop it out and change the bulbs
Old 05-07-2006, 04:25 PM
vthree's Avatar
Default Re: (bullet647)
ya they're really small like 3 bulbs.. loooooks sooo much better when u replace em
Old 05-07-2006, 06:05 PM
FernEF's Avatar
Default Re: (vthree)
quick ?? what would make them bulbs go bad...
i also have the same problem but it all happened after i swapped dashboards
Old 05-08-2006, 12:16 PM
The Lobster's Avatar
i have the same exact problem....cept every 3 months itll work for 2 days then die again for another 3 months.
Shiner_23
08-07-2020 12:47 PM
dseriesboulder
02-23-2013 07:41 PM
projectwidow
12-25-2006 05:19 PM
cilvia
10
04-21-2006 04:14 AM
remo
01-15-2005 02:16 PM
Quick Reply: AC/heater control Lights Out!!!
