Rough Idle
Old 10-21-2005, 12:49 PM
drSquish's Avatar
Default Rough Idle
I know that a million things can cause a rough idle from vaccum lines to the TPS and such but I dont think my engine is causing the trouble.
My shocks are shot (my Illuminas are in the mail). One bolt on every Hasport mount are rusted. Dose this have anything to do with the idle? Seems like the engines fine.
Old 10-21-2005, 12:52 PM
ghost_ryder35's Avatar
Default Re: Rough Idle (drSquish)
a mount wouldnt effect idle.
Old 10-21-2005, 05:39 PM
drSquish's Avatar
Yea the engine idles at 1500. Seems like this combined with the shocks is making my chassis rattle.
Old 10-25-2005, 05:40 PM
jdeemseerx's Avatar
believe it or not, mounts do affect idle but i dont think in this case try your idle adjustement screw on the throttle body its a flathead screw the reason why your "chassis" is rattling is bc its so high causing vibration it should be about half of what it is (650-700)
Old 10-25-2005, 07:45 PM
jdm Ef-9's Avatar
could be the 1st or 2nd aic motor, spray gum cutter on the back side of your intake manifold
Old 11-02-2005, 11:54 AM
drSquish's Avatar
I fixed the idle by replacing the IVAC. The shaking of the car was to to dead shocks.
Old 11-03-2005, 05:21 AM
Default Re: (jdeemseerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx &raquo;</TD></TR><TR><TD CLASS="quote">believe it or not, mounts do affect idle but i dont think in this case try your idle adjustement screw on the throttle body its a flathead screw the reason why your "chassis" is rattling is bc its so high causing vibration it should be about half of what it is (650-700)</TD></TR></TABLE>
just out of curiosity how would the mount affect what the car idled at? i just dont see how it would... thanks
Old 11-03-2005, 05:42 AM
Honda Crx's Avatar
what he said^^^
Old 11-03-2005, 05:52 AM
Default Re: (Honda Crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Crx &raquo;</TD></TR><TR><TD CLASS="quote">
what he said^^^</TD></TR></TABLE>
But why. What factors make your idle change do to mounts????
Old 11-03-2005, 06:19 AM
Default Re: (ghost_ryder35)
bump.. i am really curious...
Old 11-03-2005, 07:05 AM
i seriously dont think it does effect idle at all. i really want to know how it does. i just dont see how a bad (vibrating) mount can change your engine from idleing at 700 to say 400-500????
Old 11-04-2005, 09:01 AM
so nobody knows???
that doesnt explain anything Honda CRX so could you explain more. that just states that mounts do effect the idle. I want to know why? I seriously dont see how it could. Anyone know?????
Old 11-04-2005, 12:29 PM
so nobody knows an answer... thats what i thought
Old 11-04-2005, 01:59 PM
drSquish's Avatar
I dunno what the other guy said but my chassis rattle was due to bad front shocks. My car went from the really annoying to unnoticable. The idle had nothing to do with that. It might have done down 100 rpms after the install but that was probably due to a loose sensor wire.
minner
10-08-2006 01:30 PM
vinuneuro
01-14-2006 06:36 PM
killa_lude
08-16-2003 08:33 AM
350z-tech
11-10-2001 10:46 PM
Quick Reply: Rough Idle
