91 EF civic hatchback randomly dies while driving but turns back on
Old 11-07-2014, 01:13 PM
hatchnation's Avatar
Default 91 EF civic hatchback randomly dies while driving but turns back on
My 91 standard 4-speed hatchback randomly dies while driving. It used to sputter before it died but now it just cuts off, no sputter, nothing it just dies. After I take out the key and put it back in the ignition, the car starts but not if I dont take it out the key first. It will keep driving but it will keep dying every 5 mins or so. I have replaced the main relay, the ecu, checked the plugs (some oil in two of the plugs) and replaced the top fuel filter and the distributor but nothing worked. After I changed the main relay it ran fine for about 2 days and then it started happening again. Then we replaced the ecu and the main relay AGAIN and it worked fine for about another 2 days but it happened again. What could it be?
Old 11-07-2014, 04:42 PM
crvtectim's Avatar
Default Re: 91 EF civic hatchback randomly dies while driving but turns back on
Bad ignition switch possibly.
Old 11-08-2014, 06:27 AM
rspecturbo's Avatar
or could be a bad tps sensor.
Old 11-09-2014, 03:44 AM
Technical Hero
HondaPartsHero's Avatar
Bad TPS won't make the car cut off. Sounds more like a bad ignition switch.
Old 11-09-2014, 07:00 AM
Daily90efsedan's Avatar
I had the same problem 2 days ago.. It would just turn off and I would try and pop the clutch while still rolling and it wouldn't start, but if I turned the key all the way off it would start.. I replaced the ignition switch harness and back to running with no problems
Old 11-12-2014, 02:34 AM
Grifty's Avatar
As other people have said, either ignition switch or fuel pump are the most likely causes.
When it dies are there any lights on the dash?
woodenchef
01-15-2019 11:21 AM
mouab18c1
02-13-2016 06:30 PM
GreenGoblinEF
12-13-2009 01:06 PM
mikeycivic
11
06-29-2009 04:34 PM
tsdenny
09-07-2004 08:01 AM
Quick Reply: 91 EF civic hatchback randomly dies while driving but turns back on
