91 civic ef sedan won't start need help
What's up guys quick question hope to get pointed in the right direction my car won't turn on I turn the key and nothing but if I pushed start it it turns on right away also if get a wire and touch the starter it cranks and fires up right away any idea on what it can be ?
Keyboard Humorist
Re: 91 civic ef sedan won't start need help
There are two wires connected to the starter.
I'm guessing you are touching the small wire when you manually add power.
It could be you ignition switch or sterner relay. Possibly the ground wire that goes to the starter relay.
Where is the sterner relay at by the way? And for the ignition switch would I need the whole ignition assembly or just the wiring or the cylinder?
bullvii
07-08-2010 02:42 PM
BlazeTeck2000
12-08-2005 03:39 PM
