91 Civic with Code 1 problem - Honda-Tech
Old 02-06-2009, 08:21 AM   #1
Default 91 Civic with Code 1 problem
1991 1.5 Sedan, Automatic.
What else beside an oxygen sensor could cause a code 1? I am told that my symptons do not indicate the oxygen sensor.
Here they are. In the morning, the check engine light is not on. Around 10 minutes into the drive, the motor will run rough for around 5 seconds, then the check engine light comes on and the car smooths out and runs fine for the rest of the journey. Next time I start it, the sequence starts all over again. I have also noticed that my fuel economy has gone way down.
So any help would be greatly appreciated.
Thanks
Samahi72 is offline   Reply With Quote
Old 02-06-2009, 03:10 PM   #2
Default Re: 91 Civic with Code 1 problem
The oxygen sensor signal yada does not kick in until right after warmup. The trouble starting at about 10 minutes (= right after warmup), the reduced fuel economy and the code all emphatically point to the oxygen sensor. It is not unusual for the bad running to not exist at all times after warmup.
Check the sensor wiring. Otherwise, replace it. A new OEM (= Denso) O2 sensor costs only about $30 total through Amazon. See www.densoproducts.com for the right Denso part number.
honda.lioness is offline   Reply With Quote
Old 02-09-2009, 09:12 AM   #3
Hooray!!! I was getting ready to replace the oxygen sensor and found the wire broke. Maybe it got caught in the fan??? Anyway, I repaired the wire, reset the ECU and no more problem. Thanks for the Denso link. I am saving that one.
Old 02-09-2009, 01:59 PM   #4
Hey cool. My 91 has a clip that keeps the wire far from the fan. Make sure you do not have a vandal for a neighbor, too. Cutting the O2 sensor wire and so messing over the Honda owner would be pretty darn easy. I think a person could even crawl under most Hondas c. 1990, reach up, and cut this wire, all in about two minutes.
Your post is particularly helpful for the archives, since most c. 1990 Civic enthusiasts know that a failing O2 sensor (as in old) will not necessarily throw a code but will exhibit poor performance (like lowered MPG). If one does get an O2 sensor code on an 88-91 Civic, like you did, chances are a wire has broken completely. I think this is the first time I have ever read of someone having the O2 sensor code on an 88-91. OTOH, many have benefitted from replacing their O2 sensor even when no code was thrown.
South FL Garage Sale!! 95 GSR 95 Eg Si! P28 Turbo parts, etc etc etc !! 30+ pictures! Snail Power For Sale 89 03-26-2011 12:14 PM
Drove an AP2 today. Lightsped Honda S2000 67 02-25-2011 08:13 AM
wtb: ed3 sedan parts BiG ChOr!Zo Southern California (Sales) 305 04-29-2010 10:07 PM
parting out fully built turbo integra (full-race, gt35r) EARLdaSQUIRREL Vehicles for sale 24 05-27-2009 05:46 PM
EM1 - CEL went on again... DeathLens Honda Civic / Del Sol (1992 - 2000) 7 01-04-2009 12:05 PM
Tags
1990, 1991, 90, 91, 93, civic, code, honda, hondatech, o2, onda, oxygen, problem, sensor, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
