89 crx engine swap sohc to dohc cz - Honda-Tech
Old 08-08-2010, 02:35 PM   #1
Icon2 89 crx engine swap sohc to dohc cz
Completed engine swap 89 crx 1.5 to a 1.6 cz ,wont start no spark .Dist is off the si engine, vehicle retained its harnes and I have done the ecu mods as perscribed but do not have wire pairing for the dist as both plugs were cut also does not have connector c217 from shock tower to is this circuit required to get car to start ? Ecu is coding 6. HELP I AM going nuts.........
brendanailer is offline   Reply With Quote
Old 08-08-2010, 05:49 PM   #2
Default Re: 89 crx engine swap sohc to dohc cz
the dizzy off the 1.5 si engine will not work on the 1.6L ZC you need the dizzy from the zc i just went thourgh all this on my CRX.
92civic4door is offline   Reply With Quote
Old 08-08-2010, 06:54 PM   #3
Quote:
The 1. 5 isn't the si motor...the si distributor is from the 1.6 l sohc
Neither will work...you need the distributor from 89 integra and if you can the ecu as well
As well as more...this is all in the FAQ
gRim06 is offline   Reply With Quote
Old 08-10-2010, 02:08 PM   #4
The engine is a cz out of a si i kept thr dist that was in the engine and the wire harnes what i dont find is the pig tail for c-212 to the ecu. something is wierd the wires are at the pins on the ecu but they dont ring out per the drawing i have and the ecu codes 6 i am confused (wires from sensors to c212 no wires from c212 to ecu wires at ecu and seem to be the rire colors where are they going and i still have no spark and believe i have wired the dist rite with the exception of the ignitor *White) wire which started this c212 connector fubar
Old 08-10-2010, 02:10 PM   #5
si has a d16a6 not a "cz" i think your talking about a dohc ZC?
89ef9-87starion is offline   Reply With Quote
Old 08-10-2010, 02:11 PM   #6
Icon3 Re: 89 crx engine swap sohc to dohc cz
What is a dizzy ? I need a drink
Old 08-10-2010, 02:16 PM   #7
distributer "dizzy"
'95 CRX Engine Swap? kinglenyx Classic Hondas 2 04-09-2015 10:59 AM
Sequential shifter in Prelude 4G PreludeZ Honda Prelude 166 04-17-2009 02:06 PM
How to install VTEC controller VART swoosh into EK4 monty007 All Motor / Naturally Aspirated 1 09-17-2005 01:34 PM
ITR vs S2000 (vid) petrv Acura Integra Type-R 45 06-09-2005 10:00 PM
swap problem ecu ligth on daniel89civ Honda CRX / EF Civic (1988 - 1991) 1 09-17-2002 01:08 PM
Tags
15, 16, 88, 89, civic, crx, cz, ef, engine, honda, motor, stock, swap, tech, zc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
