Is an 89 crx dx obd0 1 or 2
Old 02-12-2015, 07:35 PM
hoffdaddy's Avatar
Default Is an 89 crx dx obd0 1 or 2
What is it stock? This car has been swapped to a d16y7, what computer does it use normally? I can find out a lot more later I can't look at the computer that's in it right now, but I'm just trying to figure out ahead of time if I may need a conversion harness for a phearable obd1 computer.
Old 02-12-2015, 09:52 PM
EFB055
~sp33~'s Avatar
Default Re: Is an 89 crx dx obd0 1 or 2
They're OBD0 stock. You're going to have to see what computer it's running the d16y7 on to determine what OBD it's running.
Old 02-13-2015, 07:43 AM
Coricivic's Avatar
obd0 91 and before
obd1 92-95
0bd2 > 96
i'm guesssing it's still obd0 because it's just a y7. look at the distributor. obd0 will have white plugs and obd1 are grey. easier to get to.
Old 02-14-2015, 08:51 AM
Keyboard Humorist
4drEF's Avatar
In all technical fairness, obd1 was the first standardized OBD system ever.
Before that, due the lack of standardization, everything is pre-OBD.
Obd0 is just a slang term for the 88~91 fuel injection system.
Old 02-15-2015, 06:35 AM
No Big Whoop
Spaceballsthelunchbox's Avatar
All you need to do is look at the distributor. If the wiring plugs look stock and unmolested you are running a OBD0 ECU as the D16Y7 will run just fine with that ecu.
whitecivic11
03-28-2010 11:04 AM
My_EFsedan
10-25-2008 11:21 AM
ludesrv
05-12-2007 08:58 PM
lance_ecl
04-08-2007 11:03 AM
e jay one
08-05-2005 03:57 PM
Quick Reply: Is an 89 crx dx obd0 1 or 2
