89 Civic Delete help!
Re: 89 Civic Delete help!
top connector is a purge valve you can just unplug it thows no codes the plug below it is a map sensor you need it but you can relocate it ....the bracket can be removed and you can remove your charcoal canister too
no write up necessary, just remove it all tuck the wire connector, cap off all vacuums, and let the fuel vent hose hang down by the subframe
Luckily i have no smog or emissions here so im good.
I have a dpfi manifold.
Blue - Is that the line where the fumes come out and do just leave it hanging down?
yellow- do i just take out that line and cover it where it leads to the manifold??
Black-How do i go about delete that whole part? As far as the lines coming out. Do i do cover them up on the manifold?
88 rex
08-04-2005 04:58 PM
VTECAcuraGSR
25
03-30-2005 02:28 PM
Westrock2000
05-19-2003 06:02 AM
